The "Lance Wolrab" Break-In Procedure - Since So Many Have Asked
Old 09-27-2004, 07:42 PM
Marcus Frost's Avatar
Real Cars
I've been getting a lot of emails/PMs about the break-in procedure I had mentioned in a previous thread, and due to our shared love for this car I wanted to provide you guys with whatever help I can give.
Few things before reading:
I take absolutely NO credit for this article. The author, Lance Wolrab, is one of the most respected minds in the MKIV Supra community, and an absolute guru when it comes to engines, forced induction, and electronics. This comes directly from him. He is reachable @ jza80-alfvza@-remove-sbcglobal.net
This was used by one member on his '04 Corvette Z06 with positive results. While it's definitely NOT definitive proof this break in procedure gives you bigger #s, it at least somewhat gives credibility to the fact it doesn't do you any harm.
Well...... I did the Lance break-in on the 2004 z06..... now, with 4600
miles on it, I decided to have it dyno tested. I went to 21st Century
Musclecars, aka LPE Jr., who are known to have a notoriously low reading
dyno. They told me all the stock 2002+ Z06's there dyno 345-355rwhp..
Then we put mine on the rollers... dyno chart here:
http://www.boostaholic.com/z06
This was reposted to a member who in addition to his Supra had purchased an '04 BMW Z4 3.0
"This is from a post to another list originally made 9/16/1999. I have been using this procedure for many years (at least 18 years). I both agree and disagree with the link you posted. I'll explain why after you see my procedure.
I have a standard break in procedure that I use, it takes about an hour if you are diligent, and when you are done, break in is complete. The biggest point of grief with a new engine is the unrelieved stresses in the pistons. You want to heat and cool them in a predictable way with an incrementally increasing thermal load. I usually start at 20% throttle and go in 10 or 15% increments until I get full throttle. Bursts should be 15 to 30 seconds, followed by 5 minutes part throttle cruise to let the pistons cool and resize themselves. You can figure out that 30 seconds in top gear at full throttle will have you going pretty fast down the road, so you need a clear stretch to do this, but I have never had a problem with leak down or bad piston fit using this technique. That crap about "XXX" miles is just so the average driver doesn't blow things up.
Also, I assemble the cylinders dry, but turn the engine over for about 15 seconds with no fuel or ignition before my initial start up, then I run it up to about 25% of redline as soon as it catches for 30 seconds or so. Once I have my initial 30 seconds and no gushing leaks, I take it out for a drive right away. I want to put pressure on the rings and valves to get them to seat well and that can't be done without a load, so off we go down the road for about 5 minutes, then return to the shop to check for oil or coolant leaks. If all is OK, back out on the road for final break in.
OK, that's what I have recommended. I disagree with Motoman because he is ignoring the whole issue of grain structure in the pistons. If you are using used pistons, then there is no need for any kind of loading tactics like these, just a few full throttle runs at soon as the oil is up to temperature to seat the rings and you are done. Cast pistons have not aligned their grain structure after casting, and forged pistons have unrelieved stresses from the forging process. Both require heating and cooling cycles to allow the grains the opportunity to align themselves under thermal load. It isn't possible to do this in the manufacturing process because pistons are not heated evenly in service. This process is no different than heat cycling your tires, a well known science among racers. I completely agree with Motoman's assessment of the manufacturer's recommendations. They are crap. I also completely agree with getting a load on the engine as soon as you can. I didn't notice any admonishments about allowing a new engine to idle, but I NEVER allow a fresh engine to idle, it is the kiss of death IMO.
Ken, in your situation, you have little or no control over how the engine was initially fired, and BMW being reasonably intelligent and diligent have already used an initial firing procedure designed to seat the valves and rings quickly. Just take it out and drive it, put a load on it, and be happy with it.
Lance
'93 TT 6 speed Coupe"
Old 09-27-2004, 08:15 PM
Mattar's Avatar
Thanx marcus for posting the article did u use Lance Wolrab break in procedure? And if u did how’s ur car running?
Old 09-27-2004, 09:48 PM
Beowulf's Avatar
2005 E55 AMG
Thanks much for the response.
Old 04-28-2006, 09:49 AM
Real Cars
I think this post needed a bump, had a few people ask about it lately.
-m
Old 04-28-2006, 10:15 AM
ima55r2's Avatar
2018 Mclaren 720s, 2021 Aston Martin DBX
Don't forget to read the AMG break-in steps for the other stuff.
http://www.mercedes-amg.com/privatel...read.php?t=149
"The AMG recommended break-in procedure is an overall program designed for
you to get maximum performance, reliability and enjoyment from your Mercedes-AMG. The purpose of this procedure is to break-in the rear axle and associated drive train components. Due to the high quality standards adhered to by AMG, the engine itself does not require a break-in procedure."
Quick Reply: The "Lance Wolrab" Break-In Procedure - Since So Many Have Asked
