E-Class (W211) 2003-2009
V1 install
Old 04-10-2005, 07:51 PM
xraymd's Avatar
2008 335 vert, 2004 MDX
V1 install
Hey all, just wanted to post some pics on hard wiring a V1 or any other radar detector for that matter. By reading posts, I learned to use power to the cigarette lighter for switched 12v. However, I couldn't figure out how to proceed from there. Well, here goes. Without starting the car, turn the key two spots so you can shift into reverse. Open the ashtray and pull up on the front edge of the trim piece that surround the gear selector. Shifting into N or R will give you more room to play with. Then, with the ashtray door open slightly, pull up on the bottom edge of the ashtray housing to undo two plastic retainers. I've popped mine out 6 times just by pulling up on the thing and nothing broke. The housing then slides out and exposes the wires to the cigarette lighter. The red and white striped one is switched 12v. I didn't want to cut anything, so I got some wire taps from Radioshack to splice in. You can push the wire from the detector into the headliner from the rear view mirror assembly all the way around to under the dash and it's completely hidden. I used the side, not the tip, of a straight slot screwdriver to push the wire in. Under the dash on the driver's side, the front of the trim piece is held in with 3 TX20 screws. Undo them and you'll have a great place to mount the power module for the detector and the hidden display. Run your display and red wires from behind the ashtray into the area under the dash and you're just about done.
Attached Thumbnails V1 install-img_1322_edited.jpg   V1 install-img_1325_edited.jpg   V1 install-img_1326_edited.jpg   V1 install-img_1327_edited.jpg   V1 install-img_1328_edited.jpg
Old 04-10-2005, 07:54 PM
xraymd's Avatar
Part 2
Attached Thumbnails V1 install-img_1329_edited.jpg   V1 install-img_1330_edited.jpg   V1 install-img_1335_edited.jpg
Old 04-10-2005, 09:46 PM
ATS
ATS's Avatar
2004 E500 / 2001 C240
Amazing.. Thanks for taking the time to show me (all of us) that.
I took that apart a few times trying to hook up an XMRadio but was unable to figure out which was the power. I even bought the wire taps and everything.
Thanks again.
Old 04-10-2005, 10:37 PM
xraymd's Avatar
All the credit for the hot wire goes to scorchie.
Old 04-11-2005, 08:37 PM
locomercedes's Avatar
2007 CLS550 Designo; 2009 Mini Cooper; 2011 BMW 335d
thanx! this helped!
Old 04-11-2005, 10:05 PM
xraymd's Avatar
Glad to help. I just noticed in the second picture that I have the ground wire in the middle of the shot. The screw worked, but I ended up not wanting to place the module behind the ashtray. Using the screw under the dash on the left worked a lot better for me.
Old 04-11-2005, 10:44 PM
JAY55's Avatar
///E63V10 ///F80CS ///Can-Am X3 XRS
Xray, got any pics of your V1 after it's installed and mounted? I just ordered mine today, thanks for sharing this.
Old 04-11-2005, 11:54 PM
xraymd's Avatar
I just mounted the detector to my windshield with the provided suction cups. The three inches of cord between the unit and the plastic surround for the overhead lighting console is all you see. It's important to get the detector as high up as possible. It gives it an extra edge in peering over the next hill.
Old 07-24-2005, 12:06 PM
chicago_fog's Avatar
see signature
My brother is a cop. They train them to aim at the front license plate. Mounting it high as possible isn't really the best idea.
Old 07-24-2005, 10:44 PM
xraymd's Avatar
You want to mount it high so you can "peek" over the next hill when someone else is getting hit. The higher the detector, the better you're range is with radar. If you're talking about laser, it doesn't matter so much. The beam is much more narrow. That said, I've had two helpful laser warnings in 3 years where I was able to slow down (once they got the guy in front of me). It was the exact same V1 mounted in the exact same spot in my old 540.
You can get installed systems that have their laser detector close to the front plate (if you've got one), but without some sort of jammer, you're only being informed of how they nabbed you. You're really sacrificing distance on radar detection (very common) for laser detection (at least where I am, not very common).
Who's right? I'll be driving through Chicago this weekend for the AMG Challenge at Road America. Hope your brother doesn't see me!
Old 07-31-2005, 12:20 PM
esport's Avatar
08' S550,,,C63!
Lightbulb
First of all thanks for installation pictures everything was perfect but I have one question how did you put the cable in the headline especially in the corner I am having trouble in the corner headliner it doesnt want to hide in!
any sugg?
Old 07-31-2005, 12:57 PM
xraymd's Avatar
The only trouble I had was in the lower left corner where the windshield comes down to the dash. Up by the headliner, I was able to squeeze it in with the screwdriver. You could also try the side of a butter knife and press it up there. It should pop in. At the bottom left corner, my cord does stick out 2-3mm.
Oh yeah, I flew through Chicago on the way back. It was slow going up from all the traffic and construction. Favorite state on this trip - Wisconsin. Those guys left their radar guns on the whole time. 2 mile warnings easy, no matter what brand of detector you had. Runner up - Indiana. What cops?
Old 07-31-2005, 01:24 PM
esport's Avatar
08' S550,,,C63!
We have the same problem the difference is that from the top headliner you know were is the left separation next to the door there is a black rubber which I hide it in there which came out perfeclty but the top corner is tough to hide. I am imagining you had it from the headliner all the way down close to the glass right I didnt do it that way. I will try to take picture to show you.
Old 07-31-2005, 03:35 PM
esport's Avatar
08' S550,,,C63!
could you post picture were you had problem in the headliner to see if it is the same as mine.
Old 08-01-2005, 10:27 PM
xraymd's Avatar
Esport - when you say headliner, do you mean at the top of the windshield? I had no problems there. My "problem" is at the bottom. Except for me, nobody had noticed it. It's not visible outside the car as the cord is hidden by the black tint on the glass.
Old 08-02-2005, 11:53 AM
esport's Avatar
08' S550,,,C63!
Here I will try to explain.
Old 08-03-2005, 08:40 AM
xraymd's Avatar
Ah ha, now we're getting somewhere. I hope. You brought the wire down the door side of the A-pillar, and I came down the windshield side. In retrospect, I like your way better and it looks easier. Anyway, I didn't have any problem forcing the wire in up at the top where you're having difficulty. I'm not sure what's up. On my car, the backing of the headliner is real flexible at the corner and there seems to be plenty of room. As I move away from the corner about an inch and a half, the flex is gone but I was still able to jam the wire up in there pretty easily. My biggest problem was running between the A-pillar trim and the dash. If I had gone on the door side of the A-pillar like you, I would have been able to skip that section. Sorry I can't be of more help.
Old 08-03-2005, 09:28 AM
esport's Avatar
08' S550,,,C63!
No problem but I will leave it that way I apreciate you installation instructions.
Old 08-14-2005, 10:37 PM
LAZARU5's Avatar
EQS 450 4Matic SUV
Hiding the last section of the wire
If you remove the A-pillar trim you will be able to tuck that last section of the power cord behind the trim panel. It's not trivial to remove the trim, but, it is possible. Remove the seal around the door frame in the area of the A-pillar. Then you can work the trim piece free of the clips holding it in place.
Old 08-17-2005, 06:04 PM
xraymd's Avatar
Thanks. Where's Mentor?
Old 08-18-2005, 11:23 PM
LAZARU5's Avatar
EQS 450 4Matic SUV
Where's Mentor?
22 miles NE of Cleveland.
Old 01-18-2006, 03:56 PM
Fly Low's Avatar
w211 E55
First off great post and pics,
I just ordered my V1 and am planning on doing the hardwire myself after reading this post. But two questions does "switched" mean that the detector turns off and on with the ignition? and I run an aftermarket nav that draws power from the cigarette lighter will there be a power draw issue?
Thanks guys
Old 01-18-2006, 04:21 PM
chenry's Avatar
05 E500 Wagon
yes
Old 01-18-2006, 04:57 PM
jimbo1mcm's Avatar
All Diesel Fleet !1983 240d stick,2005 E320 CDI Midnight blue, 2005 E320 CDI, Desert Silver, Kubota
Valentine 1
Great unit. I have one in my 05 CDI. It will save your butt, not on the highway, where you are on full alert if you are driving quickly, but on the stupid side streets that have 25 and 35 mph limits and Sheriff Bubba or the local guy is sitting there waiting to write you a ticket.
Old 01-18-2006, 05:38 PM
Fikse's Avatar
STS,FGT,12C,P85D,M4
thanks for the write up... just did mine in about 45 minutes, I mounted the V1 on the right side of the rear view mirror, and ran the cable down the passenser side of the car to the cigaret lighter.... I just tapped the red (power) and brown (ground).....
Rate This Thread
Rate This Thread:
Quick Reply: V1 install
