Squeaky Brakes & Brake Dust -
'16 528i MSport
Is anyone else experiencing squeaky brakes and massive amounts of brake dusts? It is sincerely annoying!!
2011 E350 Cabriolet..White and Almond Mocha
But brake dust with a MB is a fact of like. After 30 years of putting up with it I don't think they will change anything in the way they make brake pads. They really believe in stopping a car and dust is part of the cost. Keep the wheels waxed or coated and use a Swifter Duster to dust them off.
13 SL550, 14 E63 Wagon, 15 S550, 11 M3, 08 F430 Spider, 12 ML350
There may be a TSB out on squeaky brakes.
IMO, wax is not a good thing to put on your wheels. It has too low a melting point. A synthetic polymer like Zaino, Klasse SG, or Rejex would be much better. I began using Rejex lately and haven't seen a big improvement. I think Klasse AIO (without the SG topcoat) can't be beaten - along with regular cleaning.
1 Post
2007 GL320 CDI, 2001 TJ Rockcrawler, 2005 Scoobie STI
Dust is certainly an issue on nearly all Mercedes... My 1985 300TD dusts the front wheels like crazy. Hit them with the hose or the power washer once a week.
My brakes have been squeaking a bit, of course, this is after I took it in for the free initial service The brake dust is quite heavy, but this is my first MB, so I wasn't sure if that was normal or not...looks like it is!
'07 GL450
Anybody try the "Kleen Wheels" dust cover to prevent brake dust buildup on wheels?
http://www.brakedustcover.com
Regards,
Mel
Regards,
Mel
'07 GL 450, '02 S 80 T6
Regards,
Mel
Regards,
Mel
1) Heat buildup is a problem or they wouldn't put slots in them.
2) The air that circulates via the slots will also carry brake dust to your wheels.
Don't waste your money. Resign yourself to cleaning your wheels frequently or get ceramic aftermarket pads.
2008 C350
Yes, I did have very squeaky brakes, along with brake dust. I got very sick of it, so I took it to the MB dealer. I was then told by the dumba$$ service guy that squeaky brakes are normal. Not on a 70k car! I demanded that they were replaced, the problem was then solved. I no longer have squeaky brakes, and not as much brake dust.
1 Post
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
From the beginning
I don't know what it is with MB brakes but my first MB - a 1980s era 560SEL - had massive amounts of brake dust. I spoke with both MB certified mechanics and independents and both said, it's brake dust. Clean it off or leave it on, but trying to block it will result in heat problems.
Just FWIW.
Just FWIW.
Just FWIW.
Just FWIW.
Originally Posted by jpeardm
My 12 year old is all over that every Sat afternoon. 20 bucks for 3 cars, but he's been negotiating for 25 lately.
2007 E63
Brake dust is common with German cars. Seen them on all Volkswagens, Audis, BMWs, and Mercedes. If it were a sedan with a nice set of wheels, I wouldn't mind as it gives it the gunmetal look like on the 65 AMG series wheels. Gunmetal wheels for free!!
At least stopping power is good (as NJ mentioned) so I don't mind brake dust.
07 S600, 14 SL550
Does anybody have the recall info for squeaky brakes? I have my GL in for the A service and the service department is telling me there is no technical service bulletin applicable to my vehicle.
Thanks!
Thanks!
Yeap, squeaky & dusty!!! Manhattan MB cost me $250 to apply anti-squeak thing. but after 2 days still squeak also at service A 12000 miles MB guy told me my front have 50% and my rear have 75% left. Is MB brake worn that fast
I never need to replace brake pad on my Audi 39 month leasing terms. Looks like I needed for this one
SL500, ML350, 2 GL550's (on order)
We have had many MB with squeaky brakes due to brake dust build-up. At one point we had a late 1980's MB (I think it was a 420SEL) that had a big problem with this. The MB dealer beveled the leading edge of the front brake pads, and that seemed to solve the problem to some extent. I was told it helped reduce the amount of brake dust build-up.
