Edmunds Inside Line - Full Test: 2008 Mercedes-Benz C63 AMG
2013 650i Coupe, 2010 IS250 AWD, 1999 S500
Brute Strength and, Well, What Else Is There?
Everything you need to know about the 2008 Mercedes-Benz C63 AMG is made clear the instant you prod its 451-horsepower V8 engine to life. When the 6.2-liter beast lights off, the engine revs spike in a programmed "look at me" blip before the Merc's idle settles into a deep, throaty burble. Cue the goose bumps.
We haven't yet released the brake or slotted the shift lever into gear, and we're already trying to figure out an angle to finance one of these muscle-bound sport sedans, all $54,625 of it.
But we have to wonder if the 2008 Mercedes-Benz C63 AMG — essentially a hot-rod C-Class sedan — can possibly deliver the goods in direct proportion to this testosterone-infused exhaust note. There's only one way to find out.
Inspiring Performance
The 90-degree DOHC V8 engine in question displaces 6.2 liters or 379 cubic inches. It has an 11.3:1 compression ratio and variable valve timing. It delivers its 451-hp peak at 6,800 rpm out of a possible 7,200. Torque builds from the basement to a 443 pound-feet peak at 5,000 rpm. That ought to do it.
It's bolted to a seven-speed automatic transmission with three shift modes and two shift paddles on the steering wheel. That adds up to about 12, or something. The traction and stability control systems have three settings, one of which is "Off."
Time to brake-torque this lump to the torque convertor's stall speed and drop the hammer.
The C63 lays rubber through the first three gears — two broad strips of it because our AMG has the limited-slip differential that comes with the optional AMG Performance package.
We're instantly overcome by the strong desire to write, star in and direct a film we'll call, Schutzmann und der Bandit. All we need now is a German analog to Sally Field.
But possible movie investors will want to see numbers. If we restrain ourselves and apply a more delicate touch to the throttle with the three-stage traction control in Sport mode, the tires spin less and the C63 AMG passes through 60 mph in 4.4 seconds on its way to a 12.5-second quarter-mile at 113.7 mph. That ought to keep us clear of old Schutzmann.
It Looks the Part
You won't find a fire-breathing chicken on the hood of our 2008 Mercedes-Benz C63 AMG. Instead it has two thin longitudinal protuberances that actually make room for a broad, twin-chamber intake plenum, not the cylinder heads.
A less restrictive front grille allows extra cooling air to penetrate the radiator. The products of combustion and the grumble of the rollicking V8 shoot out the back through quad exhaust outlets and a unique rear valance. Words can't describe the glory that is the C63 AMG's unashamed exhaust note at full boil — or partial boil, for that matter. Or even simmer.
More visually striking are the pronounced front fender flares and broadened front bumper cover. A 1.4-inch-wider front track, revised steering geometry and meatier 235/40R18 Pirelli P Zero front tires are to blame for this. A trio of cooling slits sits just ahead of the tires. No rear fender bulges have been added, but the aft wheelwells are fully stuffed with 255/35R18 rubber.
Individually, none of the visual changes to the C63 AMG are radically different from the last C350 Sport sedan we tested. But their combined effect gives the C63 AMG a suitable dose of much-needed street presence.
Track Addict
The unique C63 AMG front suspension changes have been made to help improve steering precision and tire grip at the front. But with the stiffer sport suspension setup that comes with the optional Performance package, our C63 feels "pushy-loose" on the slalom. It understeers past the first couple of cones before small bumps that other cars barely acknowledge tend to pitch this rock-hard suspension sideways. A cone-free run at 68.6 mph takes some doing.
The C63 tends toward push on the skid pad, too, achieving 0.89g. When we try for more with a little throttle (and the stability control off), the tail slithers out and it all goes sideways in clouds of tire smoke. It'll look great on the big screen, though.
Lapping around the ultrasmooth surface of Spring Mountain Raceway in Pahrump, Nevada, the suspension comes into its own. A strategic lift of the throttle as we enter a corner gets the nose pointed toward the apex. As long as we don't overcook it, it's possible to put the throttle down early. On fast sweepers, the Merc likes to carry a sustained tail-out drift. The stopwatch doesn't say it's fast, but it sure is a riot.
You also get impressive-looking six-piston fixed calipers and two-piece "compound" front rotors (aluminum hub, floating cast-iron rotors) with the Performance package. They're drilled and slotted and ventilated, and it all results in 114-foot stops from 60 mph.
We've seen shorter stops with less flamboyant hardware, but our Merc does weigh 3,993 pounds. While we're lapping, bystanders radio in reports of brake smell, but we don't feel any fade. We back off anyway.
Hard Times
On the street, the optional AMG performance suspension that comes with the Performance package is just too bloody hard. Any sort of imperfection is transmitted in the form of a kidney punch through very aggressively bolstered front seats. There's no subtlety or compliance here.
It would be easy to say "Don't buy the AMG Performance package." After all, the standard AMG suspension worked great on a C63 we drove on the track recently, and it still has the tires, forged aluminum wheels, widened track and other chassis improvements.
But then you'd miss out on things we like about the Performance package (the suede-covered steering wheel) and things we need (the limited-slip differential.) After all, two stripes of burned rubber are always better than one. If the differential was available as a stand-alone option, the choice would be easy.
Actually, the choice is easy for early adopters, because the $3,900 AMG Performance package on our test car isn't available until summer 2008 anyway.
Call It a Production Expense
A front-row seat in a 2008 Mercedes-Benz C63 AMG costs a surprisingly reasonable $54,625. The Steel Grey Metallic paint that helps toughen our test car's look costs $710 more.
Typical C-Class options are available on the C63 AMG. Ours had the same $2,950 Multimedia package that includes navigation (to help Bandit find shortcuts,) Harman Kardon premium audio, a six-disc changer, 30-gigabyte hard drive, Bluetooth and an iPod connection (to deliver the Jerry Reed tunes.)
TeleAid GPS-based emergency assistance ($650) is there if it all goes pear-shaped. Seat heaters and leather seats that go by the name of AMG napa leather upholstery cost another $2,950.
As it sits, our test car's total price is $65,785, although $3,900 of that is the previously mentioned AMG Performance package that isn't for sale initially. At press time, no word on the possibility of a gas-guzzler tax was available. The C63 AMG is rated at 12 mpg city/19 mpg highway, so it might escape the tax.
This all is starting to get expensive, but it still adds up to less than a Corvette Z06. We're not saying the C63 AMG is as fast or as nimble as a Corvette Z06; it isn't. But this four-door sedan connected with us on a visceral level like no other recent Mercedes has.
We Have a Hit on Our Hands
Like the Bandit's Firebird Trans Am, the C63 AMG is happiest charging from stoplight to stoplight and running from the law. Sinuous back roads are not its thing. While the 451-hp V8 connects with us on a gut level, so does the too-stiff optional performance suspension. Buy this upgrade only if you plan on track days.
To us, the 2008 Mercedes-Benz C63 AMG is a hoot, which is what the old hot-rod guys would say. Though it lives in a German wrapper, this is classic muscle-car stuff — a big V8 engine with heaps of power and torque to generate speed, not to mention oversteer, brodies and burnouts.
We're serious about the movie. If nothing else, we'll be able to write the car off as a production expense. But Coors isn't German enough. We'll smuggle Jägermeister instead, and Hasselhoff can play the singing truck driver. It'll be a big hit. All we need is a script.
LINK and VIDEO:
http://www.edmunds.com/insideline/do...topanel..2.*#2
M
Thank you. Interesting review. I like burnouts...
08 C350 (W204), 08 ML350, 05 E350
as a person who is trying to get c63 as a daily ride, it is good to hear that not having performance kit will give bit cozier ride. As well It is good to know that it might escape from gas guzzler tax
X3 and 2012 C coming soon
That has to be the best sounding V8 I have ever heard. A little slower through the slalom than a 335i. Oh well...what this car lacks anywhere, is made up for in the overall package in my opinion.
as 12/19 EPA, that thing is going to come wrapped in a fat gas-guzzler tax, I assure you. why do people expect this monster not to be hit with that tax? wasn't it levied specifically for cars like this, after all?
C32
C32
There's definitely a hint of the devalued dollar at work. When I bought my C32 back in Oct 03, the following were standard:
- Nappa leather
- Teleaid
Both are now optional. Simply amazing.
Add to the fact that Edmunds's car had the 030 package, yet only puts out .89g and trails the 335 in slalom, which did not have an LSD even as an option btw.
And of course, the cars tops the scale at over 4000 lbs. M3 here I come.
- Nappa leather
- Teleaid
113.x almost 114
not bad for stock
that would be neck and neck with stock e55
and proably faster to 150.
cant wait to see real world runs with M3 and IS-F ... I'm thinking the M and IS will be not far behind.
not bad for stock
I got the numbers from an Edmunds comparison between the 335i Sedan and the C350. When I heard the C63 slalom speed, I recalled the slalom speed for the 335i sedan and had to double check it. I think I heard it right. I am sure different testers will have different results. I'd take the C63 over the M3 any day.
Slalom speeds-
M3: 71.8 mph
C63: 68.6 mph
335i Sedan: 69.2 mph
C350: 67.6 mph.
Check it out:
http://www.edmunds.com/insideline/do...ticleId=121574
Slalom speeds-
M3: 71.8 mph
C63: 68.6 mph
C350: 67.6 mph.
Check it out:
