Bulletins 207 coupe & 212 sedan
Received 4,412 Likes
'71 Pinto
Bulletins 212, 218, 207, 238, 257
DTB P-B-54.70/218 MAY09 Vehicles equipped with Blind Spot Assist (code 234) issuing an erroneous warning when driving along crash barriers or walls the radar sensor control unit (SGR) needs to be flashed.
S-B-54.30/222 MAY09 - 212.056/072 up to VIN A016686 analog needles in the IC are not functioning for approximately one or two minutes after engine start typically occurs in cold temperatures. The IC software will be updated.
strife (03-13-2023)
'71 Pinto
Service Campaign 2009070001 JUL09 to properly re-calibrate daytime running lamp operation, a software calibration number (SCN) update must be installed.
LI68.50-P-047173 JUN09 roller blind motor does not start at extremely cold temperatures, dealer will perform SCN coding to rear SAM increasing current to 8A.
LI80.61-P-047297 JUL09 anti-theft alarm system (ATA) activation after keyless-go (KG) unlocking via a door handle, update software to KG control unit.
LI68.10-P-047474 JUL09 rattling/vibrating noises at center IC/speaker cover because of production tolerances, felt will be installed.
'71 Pinto
LI68.20-P-047911 SEPT09 - lid of the center 212 console does not open by itself, sticks and must be opened by hand the design of the rubber stops can cause the lid to stick contact surface of buffers will e covered with felt and sealing lip lubricated.
LI61.25-P-047933 SEPT09 - 212 up to VIN 024513 under floor paneling s loose or sags, modified retaining clips will be replaced.
LI54.30-P-047934 SEPT09 - 212 as of VIN A002401 up to A0132-8, 207 F000435 – F003845, high temperatures inside the vehicle may cause the analog clock to stop or permanently run slow instrument cluster will be replaced.
LI82.62-P-048033 SEPT09 - 207.3 with panoramic sunroof, due to incorrect installation of the door lining soundproofing may press against the front door speaker causing interference, soundproofing will be replaced
'71 Pinto
LI32.22-P-048108 OCT09 – rubbing/grazing noises from the front axle when driving, replace strut boot with modified protective boot.
LI82.35-P-048244 OCT09 – washer fluid indicator on IC shows reservoir is empty although reservoir contains sufficient fluid, inspect sensor refill with concentrate and tap water at the recommended mixing ratio. 2-pin sensor cannot close circuit under following conditions: use of distilled or de-ionized water, tap water content of mixing ratio is too low, proportion of winter fluid concentrate is too high.
'71 Pinto
LI54.18-P-048131 NOV09 – 212 up to VIN A039612 wiring harness damaged in area of roof frame possible complaints vehicle cannot start, Bluetooth nonfunctional, multifunction camera nonfunctional, and night view camera nonfunctional.
LI54.65-P-048393 NOV09 – Parktronic nonfunctional, update control unit software.
'71 Pinto
LI42.10-P-048315 DEC09 rear brakes squeal, pad slots will be cleaned, pads + retaining springs replaced with guide pieces lubricated under warranty.
'71 Pinto
Service Campaign 2009110003 JAN10 VIN range A000977 to A092538 values of the backup battery (transmission selector lever) may be set too low this may lead to fault messages in the IC dealers will update the front SAM. Approximately 16,641 vehicles affected.
LI83.10-P-048662 JAN10 VIN range A057743 to A154303, water deflector below the windshield can become detached.
LI32.22-P-048597 JAN10 vehicle drops at rear axle after standing for a long time “Airmatic – Service Required” damaged sealing rings can lead to a microscopic leak, DAS leak & compressor test will be performed affected air spring will be replaced as required.
TYUS (03-09-2016)
VIN question
The last eight of my VIN are AA126102. I noted that you reference VIN's with A and then numbers. Would mine come after the ones your last listed?
Thanks.
Thanks.
'71 Pinto
VIN range references apply to the last seven characters of your VIN. A126102 is higher than A057743 and below VIN cutoff A154303 therefore, bulletin 048662 applies to your vehicle if deflector below windshield is or becomes detached and protrudes in places.
TSB Sits?
[quote=konigstiger;3917691]
I e-mailed the service manager and he responded that if I had problem as described in the TSB, I could get it fixed. No problem that I am aware of. Will call him later, but got to wondering.
Your information is really appreciated, but is there a site where I can go to find the actual TSB? I checked out DOT, Edmunds and a couple of others, but they had no listings for 2010 E's.
Thanks.
Thanks.
'71 Pinto
Gforce007 (06-03-2023)
Need your help konigstiger
Hi konigstiger,
Your knowledge is very valuable for us. I need your help, I have a 2010 E350 4matic and I am having an awkward issue with the tranny, the tranny shifts smoothly except upshiftting from 4th to 5th gear, it has hiccup at low RPMs " between 1,500 and 2,500 RPMs, 25 to 35 MPH " it's kind drops the gear, and that when the adaptive shifting kicks in, it doesn't happen when the vehicle is cold or the transmission memory is reseted. However It doesn't happen while down-shifting either. I went to the dealer 3 times about this and they said "It's product characteristics and it's your driving style, you need to drive it more aggressively" is that true? I test drove a similar car for a family member and I am pretty sure that he doesn't drive that car aggressively and the tranny was very smooth. Is it normal behavior? If not, is there any service bulletin regarding this issue? what do you advise me to do?
There was thread that i have initiated about this earlier:
https://mbworld.org/forums/e-class-w...ease-help.html
Your help is greatly appreciated.
'71 Pinto
2010 e550 coupe , 2010 ML550
I was at my local dealer and was told that there was a new update strictly for the coupes. something for the engine and tranny control unit. have you heard anything about it.
'71 Pinto
LI54.30-P-049068 MAR10 – 207 (coupe) up to VIN F014219 / 212 (sedan) to A079696 tachometer fluctuates by approximately 100 rpm, IC will be replaced.
LI54.21-P-049150 MAR10 – 207/212 LEDs seat heater, LEDs activate but heater remains inoperative rear SAM software requires flashing.
LI47.30-P-049162 MAR10 – 212 with engine 156/271/272/273 vehicle production 1/10/09 to 11/30/09 engine warning lamp associated with engine running characteristics, purge valve will be replaced.
C1A100301 MAR10 – 212 if you had additional (electronic gear selector) battery replaced dealer needs to check/replace ASAP due to poor/loose fit with terminal connector. N000000004039 is correct have dealer check VMI to see if your vehicle is included.
'71 Pinto
Service Campaign 2010030007 APR10; underbody panels may be loose or sag, dealers will replace the left & right panel fasteners. Approximately 24,100 vehicles are affected.
Service Campaign 2010030010 APR10; values of the backup battery in the front SAM may be set too low leading to fault messages in the instrument cluster, dealers will update parameters. Approximately 16,616 vehicles are affected.
'71 Pinto
LI46.15-P-049680 JUN10 - 204/207/212 at low temperatures height adjustment of steering column occurs very slowly or may not be possible at all, replace motor with shaft.
Service Campaign 2010080001 AUG10 – MY10 212 incorrect front-axle floor jack pad installed, dealer will replace pad with part # 002998065005. Approximately 833 vehicles affected, check with dealer to see if VIN is included.
'71 Pinto
Recall 2010100002 OCT10 – loss of power steering fluid, dealer will check, re-torque connection fitting to line and exchange O-ring. Approximately 85,078 vehicles affected.
LI68.10-P-050507 OCT10 – debris in glove box, wipe out using damp microfiber cloth and vacuum.
LI83.00-P-050296 OCT10 – large AC temperature difference between left and right sides, update software.
LI82.85-P-050503 OCT10 – Audio/COMAND display may flicker after warm-up or operating 10-20 minutes and/or dark spots may be visible in daylight display, replace display.
LI82.60-P-050456 OCT10 – satellite radio channels, category names and lists missing some characters, replace receiver.
LI72.20-P-050272 OCT10 – lift gate occasionally does not open and rattling noise is heard, perform SCN coding in rear SAM.
LI82.85-P-050404 NOV10 – after headunit software update pressing NAVI button causes headunit to reboot, install DAS update.
LI32.30-P-050653 NOV10 – level control malfunction in MFD and system functions correctly without limitation, flash software with DAS 11/2010.
'71 Pinto
Recall 2010110001 NOV10 - MY2011 models 164, 164.8, 212, 251 diesel fuel filter may leak due to O-ring not properly lubricated, filter will be replaced. Approximately 2,302 vehicles affected.
'71 Pinto
Service Campaign 2010110005 DEC10 – Models 164, 164.8, 212, 251 MY09-01; over time, changes in resistance in the AdBlue tank heater lines may lead to fault entries. A detection of a fault in the heater lines may occur due to an overly sensitive data threshold condition. Dealers will update the software for the SCR Control Module and Engine Control Module to correct this condition. Approximately 12,519 vehicles affected have dealer check VMI to see if your vehicle is included.
'71 Pinto
Service Campaign 2010120001 JAN11 – 204.9, 207, 212 MY10-11 cylinder head may not have been produced to specification dealers will replace, approximately 15 vehicles affected:
WDC2049561F525043
WDC2049871F522009
WDC2049871F522462
WDD2074561F060116
WDD2074561F060142
WDD2074561F060752
WDD2120561A256194
WDD2120561A256504
WDD2120871A256239
WDD2120871A256441
WDD2120871A257525
WDD2120871A257786
WDD2120871A258023
WDD2120871A258137
WDD2122871A257078
WDC2049561F525043
WDC2049871F522009
WDC2049871F522462
WDD2074561F060116
WDD2074561F060142
WDD2074561F060752
WDD2120561A256194
WDD2120561A256504
WDD2120871A256239
WDD2120871A256441
WDD2120871A257525
WDD2120871A257786
WDD2120871A258023
WDD2120871A258137
WDD2122871A257078
'71 Pinto
LI32.25-P-051123 FEB11 – 212 without Airmatic (489), 207 without vehicle dynamics (483) dull thumping noises or metallic rattling from the area of the front axle occurring @ speeds 10-45 mph, modified front struts should be installed.
LI42.10-P-051397 MAR11 – 212.077/277 without AMG ceramic brake system (B07) low mileage rear brake squeal, dealer should check batch # installed if within affected range 250-10; 264-10, 278-10; 288-10; 292-10; 307-10 pads are to be replaced.
