E-Class (W211) 2003-2009
POWER STEERING PROBLEM 2003 E320 W211
Old 02-17-2010, 11:10 PM
mariow211's Avatar
2003 Mercedes E320
Question POWER STEERING PROBLEM 2003 E320 W211
2003 MERCEDES E320 W211
HI GUYS I COULD USE SOME TIPS OR IDEAS ON MY POWER STEERING PROBLEM.
HERE IS THE EXPLANATION ABOUT THE STEERING PROBLEM, ONCE THE CAR IS ON POSITION AND I TRY TO TURN MY STEERING WHEEL IT GET HARD, AND MAKES NOISE, THE FEELING OF THE STEERING WHEEL IS LIKE THERE IS ALMOST NO POWER STEERING PUMP AT ALL, BUT ONCE I GIVE A LITTLE OF GAS AND KEEP GIVING GAS AROUND 2000 RPM OR MORE THE POWER STEERING WORKS FINE BUT IT STILL MAKE A LITTLE BIT OF PUMP NOISE LIKE THERE IS NO POWER STEERING OIL IN, BUT THERE IS OIL IN, AND IF IM DRIVING IT SEEMS FINE UNTIL I SLOW DOWN AND TRY TO TURN INTO A PARKING SPOT WHILE MY FOOT IS OFF THE GAS PEDAL IT GETS HARD, SO UNLESS THE CAR IS GIVEN GAS LIKE 2000 RPM AND OVER THE PUMP WORK WORK AND MAKES NOISE.
PLEASE IF SOMEONE KNOWS WHAT COULD POSSIBLE IS LET ME KNOW,
MY GUESS IS THAT THE PUMP WENT BAD.
THANKS YOU
MARIO
Old 02-17-2010, 11:29 PM
mariow211's Avatar
2003 Mercedes E320
please let me know if anyone had the same problem.
Old 03-10-2010, 06:22 PM
spawn01's Avatar
e270 cdi
Same Power steering problem !
Hiya !
My E270 cdi has developed the exact same problem.Infact totally the same problem, steering starts working over about 2000 Revs and gets hard below it.Not much noise though or maybe in all the reving I don't hear that.
Did you manage to get yours fixed ? any idea/advice on what this problem was !
Was it the pump or the power steering rack ?
Any advice would be appriciated. CHEERS!
Old 03-11-2010, 06:02 PM
mariow211's Avatar
2003 Mercedes E320
i bought the power steering pump but i didnt replace it yet i will let you know as soon as i replace it, but if i dont let u know by monday just reply here or pm me
Old 03-12-2010, 02:07 AM
Diesel Benz's Avatar
Originally Posted by spawn01
Hiya !
Do you have parameter steering in your car (an option for a 270CDI)? It could be the solenoid valve, these fail relatively often.
Old 04-03-2010, 06:31 PM
anwar_m14's Avatar
2003 E320 Pewter KG
A week ago i had the hard steering and noise when turning. i drove for like 10 miles so the noise was less. i checked the oil level and it was below minimum. i added oil and it worked great. just took little amount not much but it made the difference
Old 04-04-2010, 03:16 PM
vettdvr's Avatar
03 E500 and Corvette
So where did the oil go?
Old 04-04-2010, 04:19 PM
anwar_m14's Avatar
2003 E320 Pewter KG
if u mean y it was lost then it's due to high temperature over long usage.
if u mean where i added the oil then it is next to the engine oil filter cylinder, between the fan and the motor itself.
Old 04-12-2010, 06:03 AM
HE22WA's Avatar
W211 E320, W209 CLK 200K
Same problem $3000 later it was fixed!
THANKS YOU
MARIO
Hi, where did you buy the car?
I had the exact same problem in Australia, no power steering under 2000rpm (cos i did a donut hehehehe).
I bought it to mercedes and they said they never had this problem before. after some diagnosing they said it was the hydraulic power steering pump failure and charged me A$3000 to replace it!
whats the update so far?
Old 04-12-2010, 07:25 AM
paulv's Avatar
03 E320 -wife's car now; 07 Porsche Boxster S - my toy
O-rings
It leaks thru the O-rings and MB has had a TSB on this for a long time. I've also attached an article from a pro magazine related to this issue.
Regards,
paul...
File Type: pdf
Old 04-12-2010, 07:44 AM
Tom T's Avatar
2017 E300
My power steering fluid got low after 60,000 plus miles and started making that noise. I did a search and it required the Pentosin CHF11S and bought a quart from a local NAPA Auto around $20
Old 04-12-2010, 07:56 AM
vettdvr's Avatar
Regards,
paul...
Thanks Paul. New info to me,, Guess now I know I will expect mine to fail soon.
Old 07-21-2011, 10:58 PM
italyatalanta's Avatar
2004 E320
i have the almost same exact problem in my 2004 e30. did you get any solution?
Old 07-22-2011, 12:06 PM
mariow211's Avatar
2003 Mercedes E320
Yeh my solution was getting used power steering pump at car-part.com $180 shipped I got it for and problem solved
Old 12-08-2011, 03:15 PM
Paul@IGT's Avatar
04 G41
Was it hard to replace the power steering pump yourself?
Old 02-20-2012, 08:53 PM
mariow211's Avatar
2003 Mercedes E320
its actually easy access to the pump so it wasnt bad to change it
Old 10-24-2016, 04:39 AM
martobl1759's Avatar
Mercedes Benz E320 2005
I have this issue of power steering with my e320 2005, I've been using for one and half year now and all of a sudden the steering wheel started getting harder and harder. So I took it to a mechanic workshop. I replaced the power steering pump, it became soft again, and after test driving it became hard again, I changed the steering switch, but still the same, my mechanics removed the power steering rack and applied grease, still no improvement, what can the problem be? Please advise. Thanks.
Old 03-02-2017, 05:10 PM
Tomzi's Avatar
CLK 500 with Kleemann SC
Did you solve the steering? I've changed the steering pump and the power steering solenoid.. still no luck.
Rate This Thread
Rate This Thread:
Quick Reply: POWER STEERING PROBLEM 2003 E320 W211
