Map Lights in Rearview Mirror
Hey everyone,
I recently changed out all my bulbs in my 2012 W204 from standard to LED. The only two that have eluded me so far are the two map lights located inside the rearview mirror. I have searched everywhere and cant seem to find a write up about how to get to these bulbs to change them.
Anywho, I figured I would ask if someone has a write up with or without pics on how to change those two lights? I have the homelink package if that helps at all?
I might be off, but aren't these bulbs LED? The lights that shine down from my RV mirror have a slightly cooler color, and fire up noticeably quicker than a regular incadescent bulb.
They are a slightly different color but definitely not the 5K LED that I put throughout the rest of the car. If there is no way to get to them its not that big a deal to me since they are rarely, if ever, turned on. Its just one of those things that nag in the back of my head thinking "hey, you did all the other lights, why didn't you finish these ones?" I'm still searching and looking, if I do find a way to do this, I will take the appropriate pics and do a write up.
2010 E350
They are the same 194 wedge bulb found throughout the rest of the car. Stick a very small screw driver in the tiny slot towards the outside edge of the plastic bulb cover and it will pop right off exposing the bulb. Easy swap
I'll try to post some pics or a vid of whats going on. Would love to change these out.
Thanks for the help btw!
2010 E350
Just so we are on the same page, are you looking for the ambient mood lighting that is always on or the actual map bulbs that you press the buttons to turn on? If you are looking for the mood lighting then I do know it's a surface mount LED and you have to re-solder a new different color LED in the round hole. I wouldn't mess with that one myself.
2010 E350
Hmmmm....I didn't realize they had changed the bulb cover from 2010 to 2012 for that specific area. I'm at a loss on this one. It has to be a twist and drop kind of cover I would guess. Sorry I can't be of more help, my 2010 is just different I guess.
SPONSOR/MBworld Guru
facelifted models have different rear view casing. pre-facelifted was pretty easy and straight forward with just the obvious clip on the clear plastic lens. This one I took a look at and wasn't as obvious and seemed like the whole assembly needed to be opened or accessed somehow.
here's pics to maybe help?
I believe its the same bulb just a different, easier way to remove the bulbs. 194 Wedge LED. AZN Optics carries them. Great seller!
MB C250
Thanks man, i did few transactions with Azn and all i can say is
FANTASTIC service and product!
So it's the same bulb again
Thanks for the info.
i will contact mike again.
No luck here either on wife's 11 ML63, tried twisting it left/right, screwdriver on both notched ends. There's gotta be some super easy method.
You would think so. I have a tiny screwdriver I placed in the slot and again I can turn the lens left and right but as far as getting underneath is to pull out or pry out, well I am afraid that any more force than I already used would break the lens if I am doing anything incorrectly.
MB C250
Dealing with the same right now and I have tried everything SaphGreyC63 has without any luck. I am going to give up on it just like him since it looks like no one has figured this out yet.
https://mbworld.org/forums/c-class-w...ml#post6515704
I know this post is pretty old, but I have the 2010 C also and am trying to swap the lights in the rear view mirror. Do you know how to do this??
SaphGreyC63 Whats your VIN? I will get you an exploded view of the mirror and possibly some docs on how t remove the bulbs.
Nicoreyes you too.
Nicoreyes you too.
