Last edit by: IB Advertising
- Mercedes Benz E Class AMG: How to Replace Brake pads/calipers/rotors
Step by step instructions for do-it-yourself repairs
Common replacement and maintenance parts - all in one thread
here's some simple stuff that I've found perusing the internet to consolidate into one simple post
IN-DASH HEADUNIT REPLACEMENT
Suggested in the forums - Kenwood DNN991HD Headunit $799
NAV-TV Head Unit Replacement Interface Opti-1 $559
CARAV Dash Kit $43
Metra Axxess ASWC-1 Universal Steering Wheel Control Interface $47
OIL CHANGE
Mobil 0W40 (5-qt) - need 2 of these $23/ea @ WalMart for an 8.5-9qt oil change
Mann-Filter HU 718/5 X Metal-Free Oil Filter $11.35 (free shipping with Prime)
Mann-Filter CUK 3172 Cabin Filter With Activated Charcoal $27
OES Genuine Oil Dipstick $15
Mobil Jet II Turbine Oil - Quart Can $16 for S/C oil change
Oil Drain Plug; 14mm Diameter, 24mm Length $1.43/ea (need 2)
Oil Drain Plug Gasket; 14mm Copper Seal Washer; 14x20x1.5mm $0.25/ea (need 2)
OES Genuine Oil Filter Housing $43
W211 E63 Mercedes-Benz 000 180 30 09, Engine Oil Filter $15
AIR FILTERS
Mann-Filter CUK 18 000-2 Carbon Activated Cabin Filter CHARCOAL - IN HEATER CASE $62
OEM Mann-Filter C 3689 Air Filter $26 for 2
Meyle 0123210004 Air Filter $26 for 2
Beck Arnley 042-1611 Air Filter $28 for 2
Wix 46799 Air Filter $26 for 2
K&N 33-2181 High Performance Replacement Air Filter (need 2) $47/ea
aFe 31-10085 Air Filter (need 2) $74/ea
IGNITION SYSTEM
98-2010 Mercedes Benz Spark Plug Ignition Wire Set Of 16PCS $102 shipped
NGK (3588) ILFR6A Laser Iridium Spark Plug, Pack of 1 $11.88
4 New NGK Iridium IX Spark Plugs LFR6AIX-11 # 6619 $24.75/4
1 step colder NGK (2309) LFR7AIX Spark Plug - Pack of 4 $26.65/4
IC088 0001587803 UF359 98-07 MERCEDES Ignition Coil Set 8PCS + Spark Plug Set 16PCS E55 $230 (yes coils AND plugs)
Bosch 00107 Ignition Coil $55
Magnecor 85240 8.5mm KV85 CN Series Ignition Cable 1997-2011 $184
EMISSIONS
Mercedes w211 Fuel gas tank Cap OEM $50
Mercedes w211 Oxygen Sensor PRE Cat Bosch OEM $150 shipped
Downstream Bosch O2 Sensor - Exact Fit $119
MagnaFlow 444106 Large Stainless Steel CA Legal OE FIT Catalytic Converter E0# D-193-96 FRONT LEFT AND RIGHT $181/ea
MagnaFlow 444105 Large Stainless Steel CA Legal Universal Fit Catalytic Converter E0# D-193-96 FRONT LEFT AND RIGHT $148/ea
MagnaFlow 441304 Large Stainless Steel CA Legal OE FIT Universal Fit Catalytic Converter REAR LEFT AND RIGHT $165/ea
Secondary Air Pump 0001404285 Fits Mercedes R171/W203/W211/W215/W219/W220 Porsche Boxster 02-04 $182
FUEL SYSTEM
Mercedes w211 e55 AMG Fuel Pump/Filter w/ Level Sending Unit sender sensor $550
OEM Fuel Sender - Parts.com $413
RockAuto Airtex Fuel Pump/Filter $459
Torco Accelerator 32oz Race Fuel Concentrate $21.95
IAT Sensor - Standard Motor Products AX129 Air Charge Sensor $25
AUS Injection MP-50337 Re-manufactured Fuel Injector - 2005-2006 Mercedes-Benz $33/ea
COOLING
Mercedes-Benz Radiator Coolant Expansion Tank $47
Mercedes w211 (non 917) Radiator OEM Behr $256
Valeo Radiator OEM #2115003202 $349
Valeo Radiator #732855 $223
JSD AUTOPARTS B356A Mercedes-Benz Radiator Oe Quality 2115000802 $199
Nissens North America 62796A Radiator $261
Valeo 732855 Radiator $706
Hy-Per Lube Super Coolant - 16 oz. (additive like Water Wetter but cheaper) $8
Bosch 010 OEM Mercedes Benz AUXILIARY WATER PUMP (E-Class) - BOSCH 0005000386 $120 shipped
Bosch Auxiliary Electric Pump 010 Pump Part# 0392022010 $97
E55 BRAKES 2003-06
Mercedes (03-06 AMG) Brake Pad Set + Sensors Front GENUINE oem factory parts #0034207120 $299
OEM REAR PADS E55 #0044204420 $55
E55 Akebono EUR983 EURO Ultra-Premium Ceramic Front Brake Pad Set $131
E55 Akebono EUR984 EURO Ultra-Premium Ceramic Rear Brake Pad Set $99
Wagner ThermoQuiet MX1231 Semi-Metallic Disc Pad Set, Front $45
Wagner ThermoQuiet MX984 Semi-Metallic Disc Pad Set, Rear $44
OES E55 Genuine Disc Brake Caliper Repair Kit $50 shipped
Mercedes (2003+ AMG) Brake Disc Front GENUINE (x2 rotors) E CL SL 55 550 600 $392
Mercedes (2003+ AMG) Brake Disc Rear L+R (x2) GENUINE $269
Mercedes AMG (03-11) Brake Disc Rear L+R (x2) BALO coated $208
E55 Zimmermann Front Brake Rotors (OEM-like) $104/ea
E55 Zimmermann Rear Brake Disc Rotors (OEM-like) $96/ea
URO Parts #211 540 1717 Brake Pad Sensor $6.50 (2 per car)
Mercedes w211 Brake Light Switch OEM $37
Mercedes (00-09) Wheel Bearing Front Inner + Outer (2 pcs)) OEM w211 w215 w220 $96 shipped
Mercedes (00-09) Wheel Bearing Front Outer L=R (x1) GENUINE w211 w215 w220 #A230 330 03 25 $56 shipped
Mercedes (00-09) Wheel Bearing Front Inner L=R (x1) OEM w211 w215 w220 $48 shipped
E63 BRAKES (2007-09)
E63 Mercedes-Benz Front Brake Disc Rotor Genuine Factory Original #2194210212 (2pcs) $2,098
RacingBrake 2141-381 Open Slotted Finish Front Brake Rotor for C63 AMG / E63 AMG - Pair $1,097
FRONT PADS E63 AMG $191
Genuine E63 0054202520 Rear Disc Brake Pads $155
FRONT BRAKES SENSOR WEAR INDICATOR SENSOR; E63 AMG $15
REAR BRAKES SENSOR WEAR INDICATOR SENSOR; E63 AMG $15
OES Genuine Brake Reservoir Cap for select Mercedes-Benz models $19
BATTERY & ELECTRICAL STUFF
Exide Edge, AGM Battery FP-AGML5/49 $194
Aux Battery ACDelco ATX14BS (14-BS) Maintenance Free Absorbed Glass Mat (AGM) Powersport Battery $67
Bosch AL0826X Remanufactured Alternator $356
100% NEW ALTERNATOR #0121548902 FOR 5.5L V8 2003-2006 *ONE YEAR WARRANTY* $200 shipped
Bosch 0261210170 Crank Position Sensor (CPS) - $34
Horn; High Tone; 510Hz $74
Horn; Low Tone; 420Hz $94
Genuine 2118320584 Hvac Heater Control Valve $46
TYC 1-17757 #0061510601 Mercedes Benz E-Class Replacement Starter $76
Mercedes W211 Voltage Regulator ~$83
LIGHTING E55 2003-2006
Philips D2S Xenon HID Headlight Bulb, Pack of 1 - Low Beam $34/ea
Philips H7 Standard Headlight Bulb, Pack of 1 - High Beam $9/ea
E-Class W211 Passenger Side Headlight Assembly, Composite, Bi-Xenon, w/ Cornering Lamps, OEM #2118202461 $693.71
E-Class W211 Driver Side Headlight Assembly, Composite, Bi-Xenon, w/o Cornering Lamps, OEM #2118201761 $580.83
OEM E55 ~4000k Philips 9006 CrystalVision Ultra Headlight Bulbs (Low-Beam), Pack of 2 $10
OEM E63 (or E63 conversion) Philips H7 CrystalVision Ultra Headlight Bulb, Pack of 2 $27
Sylvania 2825LLBP Long Life Bulbs (city lights replacement) $3.50
SHOCKS, SUSPENSION & MOUNTS
Arnott Air Suspension C-2278 Air Suspension Coil Spring Conversion Kit $1,290
Arnott Air Suspension P-2192 Air Suspension Compressor $315
Arnott Air Suspension Left-Front (Driver) AS-2301 Air Suspension Strut Assembly $764
Arnott Air Suspension Right-Front (Passenger) AS-2300 Air Suspension Strut Assembly $764
RIGHT Front Airmatic Air Suspension Shock Assembly $525.50
LEFT Front Airmatic Air Suspension Shock Assembly $525.50
Arnott Air Suspension A-2536 Air Suspension Airsprings $516
Mercedes E55 Engine Mount Driver Left or Passenger Right CORTECO Set of 2 $190
Pelican Parts - Corteco engine mounts #220-240-27-17-98-M270 $46.50/ea
Beck Arnley 104-1757 Transmission Mount $24
Beck Arnley 101-5893 Ball Joint $41
Dorman 520-959 FRONT LEFT UPPER Control Arm (with ball joint) $80
Dorman 520-960 FRONT RIGHT UPPER Control Arm (with ball joint) $75
Mercedes (98-09) Wheel Valve Stem w/ TPMS x4 (with Tire Pressure Monitor) $77
Lemforder Steering Rack Boot ~$19
BELTS, TENSIONER, BEARINGS & PULLEYS
6K2449 Continental BELT-MULTI RIB $36
OEM Mercedes 2005 E55 AMG Supercharger belt - Dayco 5080510 $26 shipped
Gates K080505HD V-Belt $32 (5mm tighter - great for smaller S/C pulley)
ACDelco K080505HD Fleetrunner Serpentine Belt $38 (5mm tighter - great for smaller S/C pulley)
Gates K080496HD V-Belt (for S/C pulley setup) tight fit $30
OEM Mercedes Benz BELT TENSIONER ASSEMBLY - INA 55143 1122000970 $114
Genuine 1132000170 Belt Tensioner Assembly $245
Nachi Supercharger Bearing 45BG07S5AIG-2DL ~$80 (or cheaper) online
GASKETS
Passenger Side Valve Cover Gasket $16
Driver Side Valve Cover Gasket $17
Mercedes-Benz Engine Valve Cover Gasket Left & Right Victor Reinz OEM 1130221 $32
Mercedes AMG (03-06) Supercharger to Air Line Gasket RIGHT w211 $19.90
Mercedes AMG (03-06) Supercharger to Air Line Gasket LEFT w211 $19.90
Victor Reinz Exhaust Manifold Gasket $19
Mercedes (98-10 v8) Intake Manifold Seal L+R (x2) Victor Reinz $24 (for both)
Victor Reinz Water Pump Seal Mercedes (02-10 AMG) $14.90
TRANSMISSION
Mercedes Benz Transmission Fluid Dipstick Tool 722.6 $30
Red Line 30504 D4 Automatic Transmission Fluid - 1 Quart $11
Automatic Transmission Filter w/gasket $21
Shell ATF 134 Mercedes Benz Transmission Fluid 236.14 236.12 x6 QT (1/2 Case) $69
WASH YOUR CAR
32oz. Optimum No Rinse Wash & Shine < $20 shipped
Optimum Spray Car Wax $16
Meguiar's Supreme Shine Microfiber Cloths (Pack of 3) $8
Chemical Guys (IAI_503) 10.5" Grit Guard Insert $11
Meguiar's Microfiber Wash Mitt $6
really lazy? Optimum No Rinse Wash & Wax 32 oz $22
SHINY PARTS
OES Genuine Mercedes-Benz Hood Star Emblem Assembly $37
New 4 Button Remote Key Case Shell for Mercedes-Benz $9
URO Parts 211 880 0583 Grille Assembly $86
Mercedes Benz W211 Stainless Metal 4 Door Lock Pins ~$78
Want to go racing?
HJC CL-16 Helmet SNELL/DOT < $80 shipped DOT/SNELL approved!
want better throttle response? DTE PedalBox #10423700 $267
Last edited by Toadster; 11-17-2019 at 02:50 PM. Reason: updated with latest parts n pricing
I just posted a link to FCP Euro today to get the 010 pump for $110 shipped.
You even posted your $121 shipped link in the same thread. FYI, your link only has 1 left.
most of my 2 day shipments show up the next day...
Only comment is the same as above, it needs to state E55 or E63 to avoid people ordering the wrong parts.
Chef_Rizzo (04-06-2017)
the LFR7AIX is one step cooler - it seems to be the plug of preference for most modders here - I can post the stock ones too
CTSV/6sp Grocery Getter
For the oil change section--E55
Oil Drain Plug; 14mm Diameter, 24mm Length (2 needed)
http://www.autohausaz.com/search/pro...20Drain%20Plug
Oil Drain Plug Gasket; 14mm Copper Seal Washer; 14x20x1.5mm (2 needed)
http://www.autohausaz.com/search/pro...0Plug%20Gasket
