Ditching Mobil 1 - NA (Has anyone done any research on the other approved brands?)
Now that I'm outside of factory warranty I will likely stop using Mobil 1 since there are higher quality oils approved. I'm located in North America so I'm not looking at the 229.51 spec sheet at all.
Engine Oil Approval Guide
MB Sheet 223.2: https://bevo.mercedes-benz.com/d/d/en/Spec_223_2.pdf
Summary: Spec 229.5 only SAE 0W-40 and SAE 5W-40 are approved.
229.5 Spec: http://bevo.mercedes-benz.com/bevolisten/229.5_en.html
With the above in mind has anyone done any actual research (not personal opinion) on any of the other approved oils listed?
If I can find it here in Canada (likely not lol) I'm considering a switch to Shell Helix Ultra or Pennzoil Ultra Euro 5W-40 Full Synthetic.
Gasoline Engines - Worldwide (except Western Europe) -
M 152, M 157, M 133, M 156, M 159, M 275, M 277, M 279, M 285 (Maybach)
and AMG engines except M 155 (SLR)
229.5
Multigrade
2.) Restriction: Only SAE 0W-40 und SAE 5W-40 engine oils are allowed !
229.5
Multigrade
- 2.)
I recall a massive thread (or multiple) regarding oil for our cars.
From memory it was pretty heated in the end. LOL. (Oh we are so passionate!)
- What oil is allowed
- 0W40 vs 5W40
- Mobil Forumla M ESP vs Non ESP
Also why I stated actual research vs personal opinion...
Maybe start with a simpler question: Which oils from the approved 229.5 list are even available in the US and in Canada?
Probably a very short list. If The Mobil 1 is the only one that can be found, then that is it.
Kamal63 (01-27-2017)
Good friend of mine in the UK owns a MB independent and uses 5W40 Petronas, been using it for over a year now, it now uses much less than it used too when running Mobile.
MB Brooklands also use Petronas 5W40 on all C63's over here.
http://www.ebay.co.uk/itm/like/30074...f14=108&ff19=0
AMG F1 & Petronas can't be that bad if AMG F1 associates itself with them either !
https://www.pli-petronas.com/products/am_syntium.aspx
Hope that helps
Hope that helps
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
Shell owns Pennzoil and their oils (at least the base stocks) come from the same plants, so you'd essentially be getting the same oil with perhaps very slightly different additive packages. And, of the 229.5 oils that are available in NA, the Mobil 1 0W40 is the best in terms of engine protection for all-around, everyday street use. There were actually two recent threads, and in at least one of them I was discussing the actual properties of Mobil 1 0W40 and some of the other ones (I think someone liked the 229.5 Motul a lot).
What you need to take into account is that the 229.5 spec isn't just about engine protection, but also about the change interval, fuel economy and low emissions (the 229.51 and .52 specs are even worse for engine wear but better than the 229.5 for the fuel savings & eco friendliness). It's a bit of a "Jack of all trades, master of none" type scenario. If you are asking what is the best all-around oil THAT IS 229.5 APPROVED for your engine and that you can buy in NA, I am afraid the Mobil 1 0W40 is very near if not at the top of the list. If on the other hand you are asking about a better oil for a specific purpose, that's a whole different discussion - but you would both need to abandon the 229.5 spec AND sacrifice somethign else, whether it is fuel economy, tailpipe emiions, how frequently you need to change it, whether you can use it in the winter, etc.
Yeah, that's why I mentioned both the Helix Ultra and Ultra Euro since they're virtually the same. Which Motul?
Couldn't give a ***** about emissions. The question is, what's better for the engine?
Yeah, the 0W40 does have a decent amount of wear protection (I forget the PPM numbers) over the 5W40 which is better suited for the flat tappet design. Isn't it just a Group III base stock though?
This VOA was posted on BITOG after the changeover to API SN which theoretically makes what you see here the current formula you will buy off the shelf at Wally's World. The equivalent Motul is the 8100 X-cess 5W-40. Total ZDDP levels are virtually identical in both. I use the Motul in part because the temp simply does not drop below 45º ever where I live, and because of its excellent base stock. Both are great oils. If I were in a Northern climate I might use the M1.
https://www.motul.com/system/product...pdf?1381853212
Just did 3300 miles at a tank at a time 300 miles
75-80 mph
Used a 1/2 qt
Mobil 1 0w40
imho hard to do better than Mobil
Especially at $50 for 10 qts
Each oil has strength weaknesses but Mobil has been continuously improved over 30 years
75-80 mph
Used a 1/2 qt
Mobil 1 0w40
Maybe I'm just hung up on the AMG decision to move to 5W40 with no apparent reason.
Maybe the whole capillary action issue is just a load of BS...
The lifters may drain faster with the 0w40 but conversely should pump up faster
In reallity no difference since the weight is the same when the engine is hot ie shut down
And that is when most drains and mostly on the lifter that randomly aligns its oriface with the fill port
The 0W40 is actually thicker at 100°C than the 5W40...
A "dry" start could be damaging though. Also very sketchy why AMG has never released the "why" for the switch.
https://www.motul.com/us/en-us/community/446
Originally Posted by Motul
300V Motorsport Range, 8100 or 6100? Which oil should I choose?
Our 300V Motorsport range of lubricants are specifically formulated for racing applications. They are based around Motul’s unique ESTER Core® technology which combines the best performing synthetic base oils including esters with bespoke dedicated chemical additives.
The result is unrivalled power increase, outstanding lubrication and optimal protection, the best conditions for ultimate victory! These lubricants have been developed for leading Factory Racing Teams Worldwide, but also have exactly the same availability to the general public!
8100 is Motul’s top of the range passenger car engine oil based on 100% synthetic technology containing esters. These products meet the up to date and most demanding OEM engine oil approval requirements. 8100 lubricants are available in the latest and fuel-efficient 0W grades. 8100 lubricants are the safest way to keep your engine protected and operating the way it was designed to, fully compliant with the car’s warranty, whether it is in stop-and-start traffic or at full speed on the motorways.
6100 is based around Motul’s Technosynthese® technology containing esters. 6100 Products come with a multitude of official OEM approvals making sure you are using the right oil for your car. 6100 is designed to be price competitive without sacrificing on quality and performance. They are available in a wide range of popular viscosity grades.
A little further investigation suggests that the product data sheet that you linked is outdated (not surprising to me). While it describes the 0W-40 as "Full SAPS" the oil is described as "Mid-SAPS" on the Worldwide Western European websites for individual countries. My observations have been that ZDDP levels have continually decline over time. Perhaps Motul has retooled the 0W-40 already as suggested by it presence in W. Europe markets and will relaunch it in the U.S.
OK, I called a friend of mine who is a long-time user of Motul products in cars and bikes. He concurs that the 0W-40 was the only Motul oil in the "consumer" line of oils that specifically mentioned the word "ester" on the website, and that the wording as such went back well in the 2000's. The formulation of oils frequently changes over time while the name remains the same (witness the Castrol TWS I used in two M cars that today is a vastly different oil then when it was introduced).
MOTUL 8100 ESTER E-TECH 0W-40: http://www.motorspot.com/8100ow40.html
Datasheet from 2010: https://www.motul.com/system/product...pdf?1303768781
Looks like the ester based product was scrapped.
http://www.ttforum.co.uk/forum/viewt...hp?f=2&t=81271
^ Interesting. The "polarity" advantage of an ester base doesn't exist with the use of aluminum blocks, no? Or perhaps with our hot-plasma sprayed (with iron content) blocks it'll still cling longer?
Also, have you noticed any difference in oil temps or oil usage? Doubtful, but doesn't hurt to ask...
Porsche 911 Turbo S 2014! E63S 14, Audi S8 13, CLS63 12, E550 12, C63 09, all tuned
Yes Amsoil meet all specs. You can order it on line and they ship it same day.
Oil temps in M156 I have never seen then lower via oil.
Tracking I still run consistently260 to 265 degrees.
Amsoil is not on the bevo approved list? http://bevo.mercedes-benz.com/bevolisten/229.5_en.html
Castrol Edge 5w40 is
It's what I used in my RS4
