Did you know?
BLAM (11-24-2016)
Received 1,886 Likes
Clearly your salesman didn't do a good job going through the car with you after the sale...
2015 C300, 2015 F-350 Platinum, 1969 Mach 1 428cj, 2007 Roadking
You can spend a day or better going thru the manual and trying different things out. That's after our service advisor spent over an hour with us. Almost an hour just on Mbrace.
2018 E300 Lux, 2006 Corvette Z51, 2015 Mercedes ML350 (wife's)
I love the hold feature on the brake. I need to figure out how to get the parking brake to release automatically when I shift to drive. Is that a setting?
As far as I know, the parking brake automatically disengages once you put the car in drive/reverse and hit the gas. It has been working that way for me !
BLAM (11-24-2016)
Low battery voltage in a key fob will trigger a low battery warning when you start the car. The warning appears on the display in very large letters, stays on, and can be dismissed by hitting the "OK" button on the steering wheel.
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
Yep, I was turning the brake on and off manually until I realised it put it on automatically when opening the door/leaving the car and also releases it (a bit clunky) when you press the accelerator in D. For a smoother set off you can take off the parking brake manually and the set off is a bit smoother.
Trappers101 (01-17-2019)
I didn't know this!! Had the car 7 months and always released brake manually so just been outside in the wind, rain and dark to try this out. Thank you for this tip.
Can't get it to put brake on though when opening door.
Is there anyway to increase the font size on the Navigation display? The street names are too small. They stay that way even if I zoom in.
matteo882 (04-14-2017)
