2015 GLK 350 - sparplugs and engine starter replacement
Old 06-20-2015, 12:41 AM
gigelpurcel's Avatar
2015 Mercedes-Benz GLK 350
Hi,
I just purchased a 2015 GLK 350. At a first look, the car is in excellent shape, but it wont start. After replacing the dead battery, dashboard comes on and there are no error messages, but when trying to crank it, there is a sudden drop in power and the dashboard goes off, there is a loud click from the starter, but the starter does not turn the engine. I suspect that the starter is jammed.. bad.
Could you please advise/point me to instructions on how to reach and remove the starter? I would try to remove it from the engine and test it out before replacing it with a new one.
Thanks!
PS: I also need to check the sparkplugs. So, I guess the top plastic cover need be removed.
Old 06-20-2015, 08:35 PM
For who cares, I managed to remove the starter. It is located under the engine, towards its back side, and I had to remove 2 plastic splash covers and then a metal plate that also holds the steering hub. Front side of the car lifted on two jacks for better access. No big deal.
I removed the starter (very important - disconnect its power cable from the battery first, to avoid shorting out the battery when working on starter's connections under the car) and tested separately with power from a portable battery jump starter - it works fine.
So my car's problem seems not to be the starter. Next I will check the starter's power cable all the way up to the battery connector. Note - I already checked all fuses and relays; I do not have an ODB2/CAN tool, or access to Mercedes Pro diag tool, yet.
Old 06-21-2015, 10:06 PM
LBC240MIDBlue's Avatar
2014 SLK, 2015 GLK350
A 2015 should still be under warranty why not just MB fix it ?
Old 06-21-2015, 11:10 PM
I got mine from an auction, no MB warranty.
Old 06-22-2015, 09:49 AM
bop11's Avatar
350 GLK, C280
I would think the car still has its original mfg warranty no matter where you bought it. Many people sell privately. It just doesn't have a CPO extended warranty, unless it has over 50K miles.
Your problem sound like a bad alternator not starter. Was the car in a flood?
Old 06-22-2015, 10:58 AM
The alternator being bad would not prevent it from starting/cranking, however all I hear when trying to start it, is the click of the starter's solenoid and there is no turning of the engine by the starter. But the starter is good.
Thinking of a bad battery, I tried with a jumper, I also replaced the battery with a new one, but no luck.
It could be the battery/starter cables, which is the next this I am going to check tonight.
Then I probably have no other choice but take it to the dealer as there could be an immobilizer or other safety mechanism that could have blocked the car (note: there is no indication of such situation on the dashboard thus)
And yes, the car was flooded but with fresh water (not as bad as salt water imho). Now it is dried and clean. I am not sure if MB would still cover a car declared total loss by the insurance company.
Old 06-24-2015, 10:44 AM
VentoGT's Avatar
2009 E350, 2015 GLK350 4Matic
I would play dumb and try to bring it in for warranty. With a branded title you are probably screwed but it's worth a try. With a flooded car with miles of wiring and notoriously finicky MB electronics, you are in for a ride.
Old 06-24-2015, 01:21 PM
Does this look like the GLK 350's immobiliser is on?
Take a look at the attached video. Does it look like the immobiliser is active? I am not familiar with the symptoms of an immobilised car.
What actually happens in that video - I try to crank the engine, all lights come on (contact on), then you can hear the click(s) from the starter's solenoid followed by a drop in power to the dashboard, more like a reset when the power system is overloaded (i.e. starter is on but it cant actually turn).
As I mentioned in previous posts, the starter works fine. I tested it while mechanically disconnected from the engine but still wired to the car. And both its electric motor and solenoid kick in when pushing the start button of the car.
But when the starter is mechanically mounted into its place, it wont turn the engine, more like the engine is locked... or maybe it doesnt have enough power?
I did try to turn the engine manually, with a socket attached to the crankshaft pulley, and it turns, so at least part of it is not locked/blocked.
Old 06-27-2015, 12:37 AM
super7pilot's Avatar
2014 GLK250, 1983 Caterham super 7
I feel for you. But I have to say. What the hell were you thinking when buying a total loss, flooded out, electronically complex German motor car? That's like playing Russian Roulette with bullets in all the revolvers chambers.
I do wish you the best of luck.
Old 06-27-2015, 07:32 PM
420tee's Avatar
Red GLK350, blue '87 Toyota Land Cruiser
Have you thought of having a neighborhood bonfire? You say you bought a flooded car at an auction and never even asked to see it run?
I really wouldn't waste money buying spark plugs. You'll never need them.
Old 08-28-2015, 04:38 PM
waldo16's Avatar
glk 350 2012
Working a similiar problem on my 2014 glk 350
There is a "fuse" attached to the positive battery terminal, wire slides into the block,if its tripped the the "L" bracket that goes from wire to inside the block on the + post slides out.
My car was running / starting fine then stopped turning over ???...
i did remove starter from my rebuilt 2012 it had this same fuse in the pre-fuse block connected to the battery, which is an airbag deployed fuse...lets u keep some power if bags blow.
Old 08-28-2015, 06:27 PM
GLKpaul's Avatar
2013 GLK250 Bluetec
If it was flooded it could be hydro lock - nothing will allow it to turn over until cylinders are drained. Op mentioned it's "dried out" but is that the interior your speaking of ?
Although this is a couple months old would like an update on what was found...
Warranty is long gone, write offs are registered, mb will know i'm quite sure.. But trying for warranty is free they can only say no..
Old 08-28-2015, 09:09 PM
fabbrisd1's Avatar
Received 1,099 Likes on 805 Posts
A gaggle of MB's
To the OP - you will NOT be able to start your GLK - your electronics have been flooded - and frankly you will need Star to begin the debugging process - on top of that - if a key or Keyless Go butoon was in the ignition during your jump/disconnect/connect procedure - you have freid the security system on top of that.
Old 08-29-2015, 08:40 AM
NYCGLK's Avatar
GLK 350 / Porsche 993
Originally Posted by gigelpurcel
Hi,
Thanks!
The clicking is the same symptom as for a low/dead battery...i.e. when there is not enough power for the starter to engage. I see you say it's new but perhaps something takes the current away or drains it...who knows. Given complexity of electronics, even MB mechanics might not be able to figure out what's wrong. For all you know know there still might be water sitting somewhere in a connector.
For those who say just play dump and bring to the dealer, the first thing the dealer will do is run the VIN.
Old 08-29-2015, 09:10 PM
fabbrisd1's Avatar
A gaggle of MB's
The "clicking" is the same if the immobilizer has been engauged..
Old 08-29-2015, 09:52 PM
sblvro's Avatar
2020 C8, 2020 defender 110X, 2019 720S, 2014 GLK 350 4matic, 2015 escalade platinum, 2013 RRS HSELux
If it's a brand new 2015 GLK that was flooded by water it most probably fried the ECU. Replacing it will start it, if needed be the key system needs to be replaced. I know that the whole lighting system has a small amount of power to detect broken fuse or lights. If the battery was functional during the flooding, it is a costly fix hence the insurance write off. Forget about the plugs, starter, they are fine. If the battery was disconnected before the plugging then there is hope. If not you're SOL!
Old 08-30-2015, 08:33 AM
GLKpaul's Avatar
2013 GLK250 Bluetec
Before jumping to all the long hard to diagnose stuff go back to basics, the KISS rule applies (keep it simple stupid) for things like this, so do this
Pull plugs, will it turn over? If not can you manually turn the engine to see it its moving mechanically, if not its hard parts, if yes move to a full code diagnostic and see what pops up.
The less costly starting approach may yield simple fixes, and theres no saying it wasn't written off for interior damage and suspected mechanical.... Insurance may see this as a payout that never ends and just dumped it..
Old 08-30-2015, 08:42 AM
GLKpaul's Avatar
2013 GLK250 Bluetec
I would also highly recommend a full fluid change out (and i mean everything) BEFORE you start it, if there is water in the transmission, block, diff's you will just introduce more issues by actually getting it running if you don't do these thing. All filters need changing including fuel, and fuel tank fully drained, filled and then a water preventative additive put in.
You'll have to spend sime bucks up front to get this to the point of starting it without further damage...
Old 08-11-2016, 08:12 PM
zazlouz's Avatar
2015 mercedes glk250 bluetech
did you got it to start ?.
i have the exact same probleme
please help
Old 08-11-2016, 08:13 PM
zazlouz's Avatar
hi
did you got your car to start?
i have the same exact problme and would love to know whats the fix?
Old 08-11-2016, 09:48 PM
Mmr1's Avatar
2013 glk 350
What is battery voltage?
Old 08-11-2016, 11:07 PM
zazlouz's Avatar
12.4
I also tried with apower jump with no luck
Old 08-12-2016, 01:00 AM
Mmr1's Avatar
2013 glk 350
Did you try charging the old battery while it was in the car, with a charger that has a AGM setting? I think you have two batteries, one in back that keeps electronics settings. I'd still put on a charger now. I wouldn't bother with plugs , as to thinking they are bad, a starter could be, even if it cranks without load, under load is a different story. How bad did it flood? I'd remove the plugs only to see if any water is in a cilinder and to hand crank it with a breaker bar . Most likely the electronics have multiple issues. If you get a computer module get one that's used from a newer glk , or it might need pairing, Ebay or junk yard is cheap. I hope you got it real cheap. How bad did it flood? 12.4v is about 70% charged, so charge it then the second battery will charge. I hope no water is in a cilinder, that will stop it from cranking , you don't want to force it if it's hydro locked, something will break in the process, like piston rings. Remove plugs to check for water and hand crank it, there is a Foaming Fggng oil that you spray a bit into each cilinder .
Old 08-12-2016, 04:05 PM
sblvro's Avatar
Like I said, don't try even charging the battery as you will just fry the whole system. If it was flooded, it would have shorted all the electrical components. You should go to the dealer and get an estimated price for the fix. I have a lot of experience in cars like these flooded having lived in the tropics. The ECU is the first thing to fry and go from there. It would not be worth anything hence you bought it cheap. The airbags are shot, the head unit, etc. pay the dealer to see what's at fault.
Old 08-14-2016, 10:18 PM
mjhawkins2346's Avatar
2016 GLE300d 4Matic
The starting sequence is an elaborate dance with many components. I had to diagnose a far less complicated W210 some years ago and my mechanic (where I finally brought it) said the ignition switch and ECU was not giving a Drive Authorization Command to the system. You are hearing a solenoid closing but is the ECU giving the throttle assembly, fuel system and ignition system the DAC? Probably not. A STAR system diagnosis is the place to start. A lot cheaper than playing with swap-outs. Find a good local mechanic who is Mercedes certified. Pulling plugs to check for water and changing all the fluids is a good precaution too. You might be lucky it didn't try to start. There's another poster who blogged his adventure with a water logged car and the engine that hand gernaded when it tried to run with water in the engine.
Quick Reply: 2015 GLK 350 - sparplugs and engine starter replacement
