non oem illuminated star
hi i recently purchased an illuminated star from aliexpress that only comes with the star and wire which splits into black and red. the seller simply told me to connect it to 'power' . red to positive black to negative. and did not provide further instructions. i was hoping if anyone can help me install this? thanks!
http://www.aliexpress.com/snapshot/6...68538901429017
Go to our search box above type in illuminated star instructions Go to the one Jband I believe the 3rd or 4th down dated 8/31/14 gives pretty good instructions with picture
the one i bought did not come with the control unit and other wires that is included in the oem the seller just tells me to connect to positive and negative and refused to give any more instructions.
I do not have the control module which is a waste of money. My star is connected to fuse 23 under the hood on drivers side. It goes on as soon as the door opens and it stays on when ignition is on. It goes off when you turn car off and exit vehicle. It stays on a little longer than the front lights when you exit but about 1 minute later it goes off also. I also have a cut off switch under the dash so I can turn it off if I want to. I brought mine to an audio car stereo place where I live and they did an excellent job for about $100
If you go into my profile and view my posts you will see that I did have it installed and many other things.
Can u guys please post pictures of aftermarket star installed? I am also thinking of buying an aftermarket, but I am not sure about the quality of the light. Not sure if it will differ much from OEM light.
No difference at all with aftermarket as far as I can see. Have had mine in for over 2 years. I have a white star and a blue star that I can also put in. On vacation now will be home in a little over a week. I will send pictures of the installed star. If you cannot wait go into my site here and look up some of my old posts and you will see pictures of the star installed and lit up.
Timeplson (10-01-2016)
Thank you very much! Have you compared it to an OEM star having it right next to you? The reason I am asking is that from what I've seen, the oem light was not as bright as this one. Maybe that's just how it looks in the picture. Anyways, do you think it is possible to add a switch that could control the brightness of the star? Not necessary in the cabin of the car, but at least have the switch in under the hood somewhere.
Hi, I finally recieved my star. But I have to cut the grill a little bit and glue the star to it, since they have different connections. I wanted to ask you how you did the wiring. The star has two wires, red and black. How do I connect them to the parking light? I ahve never done anything like that with wiring. So do I just cut the existing wires in the partking light, burn the cover of the wires with fire or using knife, then attach wire from the star and tape it? Or is that a too vandal way to do it?))
Yeah, maybe drilling holes would've been a better way, but I didn't have the drill, so I just glued it. I did connect it to fuse 23 and grounded it to the closes screw. So it is working now. So far loving it. The only thing I don't like is that it does not go off at same time as the LED DRLS and parking lights go off. So, it waits another minute or so and only then switches off. And during that minute it looks awkward when it is the only thing lighted up. Can I get rid of that effect? Can I connect it directly to the fuse that is responsible for drls or parking lights so that they turn off together? If yes, what fuse number should I connect to?
I know of no way to eliminate the time delay. I kind of like it that way because it is the last thing to go off and I see the Emblem. I also tapped off the positive wire going to the light and ran it to a switch I installed under the dash. I can turn it off any time with the switch but so far I have never used it.
Hi, I have connected mine to FUSE23 as well. But recently I noticed, that when the car is locked, I see that the light comes up stays for like 5-10 seconds, then goes off for couple minutes. And that happpens all night long. Have you noticed that same behavior on your star? What can be my problem here?
