C63(s) Sedan Carbon Fibre Collection by Mode Carbon
Former Vendor of MBWorld
E90 M3, F80 M3, C63 507, F90 M5
Technology:
At Mode Carbon, our manufacturing process takes full advantage of a dry-layup vacuum infusion process. This allows for less resin to be used in between the carbon fibers, creating a dramatic weight advantage.
The vacuum infusion technology of our process also ensures a perfectly even distribution of the resin. The result is a pin-straight weave pattern, which generates a more consistent level of structural integrity to maximize the overall rigidity of our carbon fiber products.
100% Carbon Fiber:
All raw materials used in our manufacturing are hand-picked from Germany, France and Japan to ensure that our carbon fiber products exceed even the most strict industry standard of quality.
The carbon fiber is finished with UV protected clear coat to prevent discoloration from sun exposure. The glossy finish not only provides stunning aesthetics, but also serves to maximize the longevity of our products by increasing their durability to the elements.
The Result:
Our commitment to quality is high-grade carbon fiber that reduces weight, increases performance and improves aerodynamics. Whether your car is for the street or dedicated to track use, Mode Carbon products offer an ample blend of quality, refinement and style.
The Collection:
- Edition 1 Front Splitter
- Euro-Spec Front Trim Replacement
- Front Grille Replacement
- Mirror Housings
- Side-Skirt Replacement
- Euro-Spec Rear Diffuser
- Luftstrom Rear Diffuser
- Sedan Bootlid Spoiler
*All items are complete replacement pieces. They are NOT covers that go on top of the existing factory pieces. All items utilize OEM mounting points and hardware, no drilling required. Professional installation highly recommended.
Edition 1 Front Splitter: We are proud to introduce the latest offering in our W205 C63(S) Collection: the Mode Carbon Edition 1 Front Splitter. Incorporating styling cues from Affalterbach, our Edition 1 Front Splitter turns your C63(S) into an untamed DTM-inspired beast without sacrificing daily drivability. Our 3 piece design protrudes outward from the front bumper, as opposed to sitting underneath it, thus preserving your ground clearance and allowing for a better approach angle. Street presence is off the charts with this one, adding a sinister front personality to match the racket coming from the spooling twin turbos. The left lane is all yours, and they will move out of your way.
Euro-Spec Front Trim Replacement: this products is designed to replace the dull plastic factory trims with an upscale, glossy carbon fibre fascia that oozes sex appeal and sophistication.
The Euro-Spec Front Lip Kit includes three pieces, replacing both the lower carbon fibre lip trim and the upper canard trim of the front fascia. Not only does this add a dark, menacing tone to the nose of your W205 C63, but the pop of carbon fibre weave gleaming in the light will be sure to turn heads. These pieces feature all of the same factory mounting methods for flawless integration.
Alas, Mode Carbon has the solution to complete that upscale look and feel of the Edition 1 launch vehicles with carbon fibre all around. We have taken things a step further than the OEM launch kit by adding the upper canard pieces in the front. For those of you looking to take your vehicle a step up with our bespoke carbon fibre package, your solution has arrived!
Front Grille Replacement: Our Carbon Fiber Grille Replacement for your W205 C63s Coupe/Sedan platform is a stunning remedy for the mundane factory trim, adding a much needed dash of carbon fibre detail to the nose without sacrificing factory fitment. Our Grille Replacement is the perfect way to black out your factory grille while complimenting the rest of your carbon fibre components. This complete replacement utilizes the factory mounting points for a seamless fit and finish that is guaranteed when you purchase any of our carbon fibre products. Our Carbon Fiber Grille Replacement will integrate with your Distronic/Lane Changing Sensor without causing any drawbacks.
Mirror Housings: another subtle touch to the side profile of your W205 C63(s) adding character whilst blending in with the Side-Skirt Replacements wonderfully. If you have completed your vehicle with our Euro-Spec Front Lip Kit and Euro-Spec Rear Diffuser these bits are a must in order to keep the carbon fiber aspect of the car consistent. Replacing all the gloss black/plastic trim with vibrant yet understated beauty, they say it's the little things and we most definitely have to agree.
Side-Skirt Replacements: for the W205 C63(s) are a very complimentary carbon fiber modification that ties all the carbon fiber on the front fascia to the rear end of your vehicle. Very subtle yet extremely classy adding to the character of the otherwise tame factory finishing from Mercedes-Benz.
Euro-Spec Rear Diffuser: Our bespoke full carbon fibre Euro-Spec Rear Diffuser replaces the dull, unimpressive factory plastic rear diffuser for a rear end you can be proud of. The styling of the upper portion is drastically improved by eliminating the fake mesh pattern on the factory diffuser for a sleek and clean look.
Even though this product utilizes a full carbon fibre construction, all OEM features are left in-tact thanks to our implementation of cutting edge technologies. The rear mounting brackets around the parking sensors are 3D printed onto each and every Mode Carbon rear diffuser, ensuring a perfect replica of the OEM mounting tabs that would otherwise not be possible by traditional molding techniques. This allows for a flawless OEM fitment without blocking your parking sensors and other electronics in the rear of the vehicle that require a radio signal to be transmitted. We also include a carbon fibre tow hook cover to keep tow hook access fully in-tact should the need arise.
Luftstrom Rear Diffuser: We are proud to announce our latest offering for the ‘15+ C63 AMG Sedan, our Mode Carbon Luftstrom Rear Diffuser. This new design features bolder fins than the OEM component, for a more aggressive styling that does the quad AMG exhaust tips justice. We were careful to make sure that the styling does not go over-the-top, like some of the other big-fin options out there on the market. As always, our Mode Carbon Rear Diffuser will feature full tabs and utilize the factory mounting points for a seamless fit and finish that is guaranteed when you purchase any of our carbon fibre components.
Sedan Bootlid Spoiler: There is no better way to make a statement than with our signature style Bootlid Spoiler for the W205 C63(S) Sedan. With a Mode Carbon product, you get that signature aggressive styling that is sure to be imitated by the masses. Our goal from the onset of designing this piece was to add some much needed aggression to the otherwise rounded trunk line of the W205. The lines of our Bootlid Spoiler aim to flatten out the top curve of the trunk when viewing straight on from the rear, while adding a robust muscular side profile to match this car’s serious performance characteristics. The little things definitely add up here, completing your C63s in our range of carbon fiber products definitely adds that touch of class that Mercedes-Benz is so synonymous for. If your attention to detail is keen then be sure to add this item to your wish list!
wow this is incredible looking and think I have just been sold on white.
can you PM the price of the front lip and rear diffuser. haven't even sealed the deal on the car yet and already sold on this and tint as the first addition!!!
Idk if Nicholas and Sam will get mad at me but here is a good view of the new front end.
The carbon fiber A-wing is so clean
Yay finally! Please pm me price for front and rear pieces please. No need for spoiler already have oem carbon fiber.
Ps: do these pieces have a weave that matches the oem? Not a deal breaker just curious.
Thanks Aman! We are really happy that the parts are finally fitted to your car.
Thank you!!!
PM sent!
We are currently offering exclusive introductory pricing for all MBworld members!
simple beautiful pieces
2nd to none
2nd to none
Thanks brother
Thank you brother hope all is well with you!
They''ll come up with an AMG GT-R later this year which should be the next level. But the real wake up call will be when they release a Black Series if they even do it!
Please let us know when you are ready! If you would like to purchase the products beforehand to take advantage of our introductory pricing please let me know!
Thank you PM sent!
