Post your C450 with Aftermarket Wheels
Old 03-23-2016, 05:17 PM
atl 2 chi's Avatar
Current :2018 E63S and a 2017 GLE 63S . Prior, CLA 250, C450 AMG, 2017 AMG C63S
Just wondering if anyone has had any success with Aftermarket wheels for their C450. If so, please post photos including rim size and tire specs. I have not had any luck with Carlsson nor Vossen.
Old 03-23-2016, 05:28 PM
lbowroom's Avatar
C450
http://www.mandruswheels.com/ lists C450 specific applications
Old 03-23-2016, 11:53 PM
nadeau's Avatar
2016 C450
My wheels should be in pretty soon will post pics once they are one, went with HRE FF01
Old 03-24-2016, 12:23 AM
atl 2 chi's Avatar
Nice! What offset did you go with and what size wheels and tires?
Old 03-25-2016, 12:23 AM
nadeau's Avatar
2016 C450
So it looks like the shop who guaranteed me that the FF01 would fit my C450 was wrong, they ordered 19x8.5 + 45 for front and 19x9.5 +45 rear FFS!! but according to HRE a 5mm spacer will work, guess i will find out when the wheels arrive at the shop I'm going to, if not I'm back to square 1 and lost time
Old 03-25-2016, 01:29 AM
atl 2 chi's Avatar
I know exactly what you are going through. I ordered some wheels and was assured that they would fit. Same specs as yours except the rear was +50. Well, the tried to mount them and it was a no go due to that control arm. They tried again with a 16mm spacer and the front tire(245/40/19) hit the arm. It was then suggested to use a 225/40/19 up front with the spacer. Well, the rim stuck out to much for my taste and look how close the rim is to the suspension. See below.
So it was back to the drawing board. They then ordered a front wheel, 19x8.5 +35 and will use the 225/40/19. I also have H&R springs that I am waiting to install.
Waiting on that wheel now. Let me now how yours turns out.
Old 03-25-2016, 01:45 AM
atl 2 chi's Avatar
I am wondering if we have to go with a 19x7.5 wheel like the factory to make it work.
Patton250 (09-08-2019)
Old 03-25-2016, 03:15 AM
nadeau's Avatar
2016 C450
AHHH man i don't want this to happen lol if these don't fit the shop said they will refund my money, if thats the case i will just install my lowering springs and but a spacer kit to make the stock wheels look flush until we can figure out proper fitment on these damn cars
Old 03-25-2016, 03:20 PM
BMWMB71's Avatar
2016 C450 break AMG Sport
Yes! That's why i ordered OEM 19" AMG wheels, optional for the C450.
Old 03-25-2016, 03:31 PM
Former Vendor of MBWorld
OSMS_Carlsson's Avatar
Mercedes-Benz
If you are having multi pc wheels made, they can make the wheels with a 8.0x19 front with a ET32 offset, this should position the wheel to the outside fender the same as an 8.5 with a ET45, the 225 factory 19" tire will sit more square on this rim, and should give the clearance necessary for the front Control arm.
The European tuners have not provided any update with their applications just yet, for cast 1pc wheels this is going to take time. If you want to run a 19" factory set up, you can make the factory AMG 19's a little more aggressive by using their 19x7.5 front with a 12mm spacer. I have gone back to the factory set up on my C300 using the 19x7.5 front and 19x8.5 rear, running a 12mm spacer up front, and a 15mm spacer in the rear. No rubbing and the wheels fill out the fenders nicely. I did not want to lower my car, so this option really gives the car a more aggressive appearance without sacrificing the ride and front end with driveways and tire blocks.
For now, I would strongly suggest that individuals like yourselves save your money and wait for the industry to catch up...you guys are experimenting with tires, wheels, and then your expensive cars only to find out that things don't fit...I would avoid getting too creative with tires as you may end up rubbing a fender and having a paint repair expense.
Because the C class has a good portion of cars manufactured by US production, the European tuners will require time to get these cars and test them. Also, going to production for new cast wheels takes a great deal of time, and may end up not being a worthwhile investment for that tuner, so we may see some companies not even offering an application for this specific model.
Jim
Johnyturbo (01-09-2021)
Old 03-26-2016, 02:51 PM
*Knowledge*'s Avatar
The Infamous C450
Ah man that blows.
nadeau (03-30-2016)
Old 03-27-2016, 01:27 AM
nadeau's Avatar
2016 C450
Jim
Thanks for the advice Jim if these spacers don't fit they will refund me my money and thats what i will be doing, i will wait until next summer to figure out what i want, and will go for a custom 3 piece forged wheel
Old 03-28-2016, 01:05 PM
lbowroom's Avatar
C450
If you select 20" wheels at Tire Rack they have OZ Monaco HLT 20x8 with a 35 offset front and 20x9.5 with 52 offset rear for the C450
Old 04-07-2016, 02:48 PM
Mercedes-Benz
This set up sounds like a good option.
Old 04-07-2016, 05:02 PM
lbowroom's Avatar
C450
The odd thing about those Monaco's, I believe they list the 20x8 at 23 lbs but list the 20x9.5 at 34lbs. Seems impossible to me for 1.5" width difference to add 11lbs. I emailed OZ but no reply. My guess is one of those is a misprint, I hope the heavier one.
Old 04-07-2016, 08:43 PM
atl 2 chi's Avatar
Jim
Thanks Jim for your expertise!
Old 04-14-2016, 11:12 AM
nvestr's Avatar
2016 C450 AMG
Is it confirmed that there is no way an 8.5" width rim will work properly on the front? I want to completely rule them out if that's the case. All the rims I'm looking at seem to come in 8.5" minimum width...
Old 04-14-2016, 01:56 PM
ohio2kentucky's Avatar
W204
They C63 wheels? Can you confirm they fit?
Old 04-14-2016, 09:07 PM
atl 2 chi's Avatar
That's the conclusion I came up with. I hope are selection increases to have aftermarket wheels fit our cars. Wonder what the motivation was for steering away from the 8.5..
Old 04-15-2016, 01:01 PM
lbowroom's Avatar
C450
I don't think they purposely steered away from the 8.5. They wanted to put the AMG steering rack in but didn't give us the wider fenders therefore they had to run a narrower wheel.
Old 04-15-2016, 04:13 PM
Graycat305's Avatar
996 Carrera, G55 AMG
Change the front fenders out to c63 versions?
Old 04-15-2016, 05:08 PM
BMWMB71's Avatar
C63 wheels don't fit.
These are my wheels.
Old 04-15-2016, 06:33 PM
The Infamous C450
Regardless of the offset? Geez that's weird. I'm about ready to place an order but I want to know exactly what fits to tell the shop what I need.
Old 04-18-2016, 02:31 PM
lbowroom's Avatar
C450
By the time you space them far enough to clear on the inside, they wont tuck well into the fenders.
Old 04-18-2016, 02:34 PM
lbowroom's Avatar
C450
The C63 fenders are not only wider, they are longer. They won't line up with the grill or hood. There's a thread somewhere in here where a guy is putting C63 front end on his hybrid I think. It's a major project.
Quick Reply: Post your C450 with Aftermarket Wheels
