2002 G500 build/ restoration/ conversion photo thread
Rating: Thread Rating: 17 votes, 5.00 average.
Old 03-23-2016, 09:23 PM
Kobzarhomes's Avatar
2011 Mercedes E550 Sport
Hello everyone.
Couple months ago I picked up this 2002 Mercedes G500 for a very good price. Car needs some TLC, it's exactly what I was looking for. Over the next few months I am going to be repairing it, restoring it and updating it with 2016 G63 parts that I purchased from a forum member on here 👍😊.
I already took it apart and I apologize that I didn't take pictures off it right when I got it.
As you can see I already took off the front end, front axle, front suspension, exhaust, remove fender flares and rear bumper. My goal is to take it apart as much as I can, do some body repair and detail the undercarriage. I'm going to sand and soda blast the rust spots underneath and paint them with rust resistant paint.
I will try to post as much as I can on here.
Popular Reply
08-17-2018, 09:42 PM
Kobzarhomes
First drive down the street to a gas station and around the block 👍
Old 03-23-2016, 09:29 PM
Few rust spots so far and few more out there. Overall there is not a lot of rust just in your typical places.
Driver side door mirror.
Could had previous damage / rust
Scratches on the hood
Couple of large stone chips and some rust
The following 2 users liked this post by Kobzarhomes:
patrick@scp (11-11-2019), Wassaby (04-08-2018)
Old 04-08-2016, 04:03 PM
kotton's Avatar
2011 E550 , 2006 G500
Awesome pics! Im looking forward to seeing the progress.
Old 04-08-2016, 04:08 PM
Thanks! Was gone for couple weeks, eager to get back to work on it.
Old 05-02-2016, 01:28 AM
Been sand blasting the frame and suspension parts. Painted the front section of the frame with Eastwood Rust Encapsulator then go over with Undercoating. Going to start putting the front axle back on later this week and start taking the rear axle apart to paint the rear section and suspension components.
Old 05-02-2016, 01:31 AM
Doing some repair to the rear lid due to having spare tire dent.
Old 05-02-2016, 01:43 AM
Some of the products I use for frame restoration and treatment
Old 05-03-2016, 07:36 PM
kotton's Avatar
How well do those rubberized undercoatings blend with the grey stuff that was put on from the factory?
Old 05-03-2016, 09:06 PM
My plan is just to put it on the frame and axles. My underneath is gray so I'm just going to steam clean it. I did not find any rust on the under body itself, just couple spots where some brackets were attached to it. Those will be spot treated and touched up.
Old 05-05-2016, 01:20 AM
Painted front suspension bits and front section of the frame with chassis paint. *new bushings on all the parts*
Old 05-05-2016, 09:22 PM
Front suspension coming together. G63 springs and shocks. Brand new bushings everywhere.
Old 05-07-2016, 10:53 PM
Front suspension all assembled (besides brakes). Changing brake color from silver to red. Moving on to the rear end now👍
Old 05-09-2016, 01:01 AM
just1time's Avatar
s550
wow...impressive. can't wait to see the finished project. any plans for the interior?
Old 05-09-2016, 01:05 AM
Thank you.
The plan is to completely reupholster the interior to a different color. Something similar to Barabus look.
Old 05-10-2016, 07:41 PM
pitpro's Avatar
G500
Your skills are very impressive!
You will feel great driving that truck after
literally rebuilding her.
Those calipers look small for such a heavy
truck. No wonder I was always worried about
stopping in a hurry in my 2002.
ChefJody (05-02-2021)
Old 05-10-2016, 07:57 PM
Thank you
Hopefully the ones I got from G63 will do the trick 👍
Old 05-11-2016, 08:58 PM
Today I took apart the rear end suspension, dropped off rear links to get new bushings pressed in and replace passenger side axle with the one I got from G63. Axle replacement went very smoothly to my surprise : )
Brabus388 (10-30-2019)
Old 05-12-2016, 01:57 PM
G63 Front and rear calipers that I got came in silver, decided to paint them red.
Old 05-12-2016, 09:19 PM
Replace left rear axle and painted rear end frame and part of the rear axle.
8899 (01-04-2017), pitpro (05-12-2016)
Old 05-13-2016, 07:30 PM
Painted rear links and finished painting rear axle.
Also sprayed "inner frame protective spray" in some of the frame crevices.
Jens Curtis (05-10-2020)
Old 05-17-2016, 08:35 PM
Assembled rear suspension. Next on the list is to install a new rotors and calipers.
pitpro (05-17-2016)
Old 05-18-2016, 05:38 PM
Some more goodies arrived from parts.com. Miscellaneous gaskets, seals, molding, trim, grills, etc... Its about the details.
pitpro (05-18-2016)
Old 05-23-2016, 01:44 AM
Took off my original illuminated door sills today. Wanted to see how they are attached and if there will be any issues with attaching custom door sill I purchased. It appears they were original Mercedes sills and are attached with a double-sided tape to a plastic door sill which is attached to the vehicle. Looks like the once I purchased will work just fine 😊👍
Old 05-23-2016, 01:48 AM
Here are the custom door sills I purchased.
Old 05-23-2016, 01:52 AM
Removed all 4 window seals (on the outside of the door window). All were rusty. New replacements arrived couple days ago 👍
I'm pointing to which door window seals that I removed.
You have already rated this thread Rating: Thread Rating: 17 votes, 5.00 average.
Quick Reply: 2002 G500 build/ restoration/ conversion photo thread
