Screeching Brakes on the GLC
Old 04-07-2016, 03:43 PM
nycrounders's Avatar
GLC 4Matic
I wanted to start a post to track this issue. If someone has this resolved, please let me know.
Does anyone else have this issue of screeching brakes when pulling out of the garage or driveway? The issue comes and goes depending on the day. Usually when the weather is cooler. The sound is loud and annoying for a new car.
Is there a fix for this issue?
I brought my GLC into my service center and gave them the bulletins as posted in this forum:
https://mbworld.org/forums/c-class-w...ng-brakes.html
LI 42.10-P-060688 - Install special order shims for front brakes to eliminate cold weather squeal to adjust the angle of the pad
and this bulletin LI#: LI42.10-P-063311
I was told that those are for the C300 and doesn't apply to for the GLC. No solution for the GLC as of now.
Rmlasalle (02-14-2018)
Old 04-07-2016, 04:25 PM
JEVA's Avatar
2013 BMW X6 - Soon to be GLC300 4M
Check some of the posts here: https://mbworld.org/forums/glc-class...ml#post6739097
Old 04-07-2016, 04:31 PM
GLC 4Matic
Originally Posted by JEVA
I read those posts as well but didn't seem like there was any solution over in there as well. I'm at around 1,700 miles on the car and the issue is still around.
If my service center calls with a solution I'll let everyone know as well.
Debferrell1rn (11-20-2020)
Old 04-07-2016, 05:30 PM
DBV
DBV's Avatar
2016 GLC and 2017 BMW 530xi M-Sport
We have the same issue and at 3,300 miles now. Inexcusable and embarrassing, for a luxury SUV. No fix for it so far, but hopefully taking it back in next week.
Old 04-07-2016, 06:00 PM
dieseldoc's Avatar
2016 GLC300 Dakota Brown on Espresso Brown Leather, 2014 C250 Sport Diamond Silver
Have not had so far in a little over a month ownership.
Old 04-07-2016, 09:15 PM
JEVA's Avatar
Doc, I wonder how the timing of the build of your car compares with those having the issue? Sometimes they "fix" things in production when issues are identified so if there's a recall or service bulletin, they have less to fix and they aren't perpetuating the issue with every build. Companies are usually very slow to publicly acknowledge and address issues. Given the time it takes me to run things through corporate legal for approval, I know why. And my stuff is generally way less important/visible than this stuff.
Old 04-07-2016, 09:22 PM
dieseldoc's Avatar
My car was built last week of January. Will ask one of my fellows if his wife is having any issues with her car. If she is I will find out the build date and post. They bought their GLC before I got mine. They bought one that was in stock.
Old 04-07-2016, 09:53 PM
larrypmyers's Avatar
16 GLC 19 Volvo XC40 06Corvette Z06
I had the same problem. Backing down the driveway in the morning and listening to brake squeal.
That said, its not unusual for disc brakes to squeal, especially when cold. This problem is exacerbated when the brake pads are hard.
To cure the problem I employed a process known as bedding. This involves making several maximum effort stops from about 80 mph. The objective is to get the brake pads hot, very hot. So hot you can smell them.
As expected it cured my squeal.
Old 04-08-2016, 07:24 AM
DBV
DBV's Avatar
That has not worked for our brake squealing. Never have experienced squealing so loud in any car we have owned. Plus, this does not just happen when it is cold out. I think it is the same issue that some of the C class owners have, but Mercedes has just not acknowledged it yet.
Old 04-11-2016, 06:03 AM
Flyboy82's Avatar
95 SL320
I just installed new pads and rotors on my E320 and the same thing was happening to me. I heard taking the pads out and taking 100 grit sand paper and sanding the edge of the pads all the way around will stop the squeal. I tried this and then took the car out and hard braked it several times from about 50 miles per hour.
Only after a few times it started to work. The squealing was worse when you were backing up and putting the brakes on lightly, but finally the noise has gone away. Hope this helps.
Old 04-11-2016, 07:05 AM
Mikeyking's Avatar
Mercedes GLC 250d
It also caused two major pile ups and several near misses
Old 04-11-2016, 10:36 AM
guido3's Avatar
2016 GLC300 4Matic
Mine has a build date of 11/15. Had very minor brake squeal on backing only until (it seemed) the rotor metallic coating had completely worn off during the bed-in period. No squeal now. Others say this was pure coincidence. But, of course, with DBV's 3,300 miles and continuing brake squeal, something else (?) is happening.
Old 04-11-2016, 08:24 PM
Hello Mikey, Very funny. Actually finding big pavement was a problem. My mechanic showed me a two mile stretch of very lightly travelled rural road, perfectly straight, with no driveways or intersections and sight lines from one end to the other.
Fortunately, this illegal activity is only done about once a year when my mechanic beds the track pads on my Vette.
Old 04-11-2016, 08:52 PM
dieseldoc's Avatar
Very cool.
Old 04-12-2016, 01:26 PM
DBV
DBV's Avatar
We took our GLC to the dealer today to check out the squeaking brakes. They knew right away of the issue and also said Mercedes is well aware of it and working on an official fix. It sounds like the parts they will need use (brakes, etc..) are on back order for potentially a couple months.
I am just glad Mercedes knows it is a problem and is going to get it right.
Kind of funny, backing out of the MB dealer and our GLC made the very loud squeaking sound and everyone outside turned and looked.
Old 04-19-2016, 09:58 AM
GLC 4Matic
Keep us in the loop when you hear back on the official fix.
Old 04-24-2016, 08:38 AM
bgmillhouse's Avatar
Mercedes Benz GLC
Guys when you say squeaking / screeching breaks is it like a groaning noise and where the brakes feel a bit grabby?
Old 04-24-2016, 09:03 AM
Flyboy82's Avatar
95 SL320
I found the problem..it was the belts afterall.
Old 04-24-2016, 07:04 PM
DBV
DBV's Avatar
No - It is when you go in reverse and it is a extremely loud squeeking/squealing noise. It has continued to occur even in the warmer weather.
Can not wait until Mercedes has an official fix.
Old 06-21-2016, 08:42 AM
Glcabc's Avatar
Glc
Hi DBV, any update on your reverse squeeking issue? Did your dealership come back to you with an official "issue number" (forget what it call) referring to this problem? Our Glc have just reaching 2000kms and start having the same issue. Took to the dealer but they have no idea...
Thx!
Old 06-21-2016, 09:51 AM
JEVA's Avatar
Thankfully, I have not experienced this issue. I have nearly 3k mi on the clock now.
Old 07-26-2016, 06:20 PM
GLC 4Matic
Got back today with an advisory fix.
Some good news for us waiting for a solution.
based on LI 42.10-P-063978
They replaced both front disk brake pads and lubed the contact point of pins and brakes. I hope that is the end of the screeching noise in the morning
Thx!
Old 07-27-2016, 04:09 AM
Rotelman's Avatar
GLC 250d
Same issue here. Reversing out driveway sometimes causing loud squealing from brakes. quite embarrassing for a car that costs this much. (250D Aus )
Old 08-08-2016, 05:00 AM
B2FiNiTY's Avatar
'16 GLC300
Mine only happens in reverse. Doesn't matter how long the car has been driven.
Old 08-12-2016, 10:29 AM
Glcabc's Avatar
Glc
Thanks nycrounders!
Any chance you can get hold of a copy of the TSB from your dealer like one below?
http://www.revbase.com/BBBMotor/TSb/...dPdf?id=186981
My dealer in Australia try to help but they can't find the details base on this TSB number.
Many thanks!
Quick Reply: Screeching Brakes on the GLC
