C63/C63S AMG
Rebellion Piggy Back Installation Thread..
Old 04-16-2016, 09:18 PM
CT-AMG's Avatar
AMG C63S
Guys, I just went through the install of the piggy back and I wanted to start a thread for those of you doing it or planning on doing it. Anyone doing this themselves is the bravest person on earth. This is not an installation for the novice.
So, I arranged a power install at a place called P1 Motors in Stamford Ct. This place has to be the most insane garage I have ever seen. Mostly Ferarri's but tons of other muscle cars. GTO's, Porsche GTS, Twin Turbo Ferraris, GTR's.. The list went on and on. The owner's name is Tommy and he put his best mechanic on the install.
According to him, the instructions are horrible and not very specific. For example, they do not recommend or even suggest where the module should go. There are half a dozen ways to run the wiring harness and the way we ran it we had to extend the ground wire. It could have been installed without doing so, but the idea was to get this completely hidden and by completely I mean no trace at all.
A few mods we had to make. Extending the ground. Trimming a small plastic piece to allow for the harness to clear the compartment on the passenger side, and velcro for the module to make sure it stays put.
The job took 3 hours, perhaps even more with all of the head scratching, hand contorting and attention to detail in hiding the wires. The ONLY visible wires are about 4 inches long and cross right in front, dead center above the radiator.
I will let the pictures speak for themselves. I will try to answer any questions you may have but, if you are interested in having P1 do it, I give them my highest recommendation. Not a scratch, not a single issue at all. 100% awesome.
P1 motorcars "Tommy" 203-276-0749
http://www.p1motorcars.com
You can tell them Eric or George from the MB World Forums sent ya!
Attached Thumbnails Rebellion Piggy Back Installation Thread..-img_1341.jpg   Rebellion Piggy Back Installation Thread..-img_1352.jpg   Rebellion Piggy Back Installation Thread..-img_1353.jpg   Rebellion Piggy Back Installation Thread..-img_1354.jpg   Rebellion Piggy Back Installation Thread..-img_1355.jpg
Old 04-16-2016, 10:44 PM
Iceman II's Avatar
2015 C63S / 2015 BMW M4
+1 That sounds about right except I'd add "all of the head scratching, hand contorting, crying and attention to detail in hiding the wires." Only brave souls will try this at home.
Just in case others are wondering, my guy wrapped the tuning box in plastic -- see picture for location. I believe the box is weatherproof but this is what he recommended. Anyone else here running 91 Octane?
Old 04-16-2016, 10:51 PM
CT-AMG's Avatar
AMG C63S
Iceman: You grounded the box in the place I believe Rebellion suggests we ground it. However, by doing so you leave a "hint" that something is installed because that bolt has nothing connected to it from the factory. Will anyone notice? Probably not.
We thought about wrapping the module (box) in plastic or some sort of ziplock bag but, decided against it. Why? Because Rebellion didn't suggest it. Because it is supposed to be water tight. In addition to those reasons, we felt that the plastic wrap would retain moisture in the bag and retain heat. Where it is located there is little chance it can get wet but, the engine bay is so hot to begin with, that wrapping it with plastic might melt it or create more heat around it.
How long did your install take? Any dyno numbers?
Also, the part we shaved was exactly where your module is. Your installer didn't put it back and just removed it completely. We thought about that too but ultimately modded that part so we could slide it back and look stock
Old 04-16-2016, 11:03 PM
bgm130's Avatar
2016 C63S
Glad the install went well. Hope you are enjoying the huge HP boost. I took a few hour trip with the wife and she IMMediatly noticed(and ahe never does). She asked why it seemed so much faster!
Yeah the directions are pretty terrible to be honest. Really need more then 4 photos and some better pictures of exactly what thing to unplug. The best part is where they say to "use the viewing hole" to attach boost sensor 1. Which is a 1 inch square haha.
That cover the Mb puts on all the wires is an absolute nightmare. My hands are all cut up and swollen haha.
I was actually thinking of mounting the box where you put it but I ran the wires before I thought of that and don't have enough slack.
Old 04-16-2016, 11:05 PM
CT-AMG's Avatar
AMG C63S
Haven't had the time to test it yet, but at 45 I hit the gas and the back end slid out so I suppose its producing more HP, just can't stick it to the ground..
Old 04-16-2016, 11:13 PM
Iceman II's Avatar
No dyno numbers. I travel too much and just can't get there while they are open. I am curious about the numbers for 91 and 93 octane. I'm in CA and use 91.
The install took over an hour and my install guy echoed what you posted. He's an authorized Dinan guy and also installs ESS and other harnesses. This was quite the challenge.
I had the same thoughts about the plastic but he said it shouldn't be a problem. I took the picture above today and checked it -- no problems with the plastic at all. I agree -- its probably not needed but thought I'd share the pic anyway.
As for the ground, I'm not worried since my CA deals with "tuned" cars and he has a pretty good relationship with my install guy. If I experience a CEL, my install guy is just minutes from me and agreed to troubleshoot any issues before I head in to the dealer. If I need to go to the dealer, he'll remove the harness for me first.
Old 04-16-2016, 11:21 PM
CT-AMG's Avatar
AMG C63S
If your guy did it in "just over an hour" he is a master unlike any other. My guy, even after doing it for the first time, said there was no way it could be done in less than 2 hours. Too many ties to cut and reinstall, too many cables to hide properly and of course getting to those sensor clips is ridiculous.
Anyone who thinks this can just be removed and reinstalled for dealer visits is highly mistaken. The good news is that Rebellion does provide a jumper plug that allows you to remove the module and "plug" a jumper in its place for 100% stock factory readings but, the harness doesnt get removed.
Thats the main reason for my wanting no evidence of the harness, so that if I install the jumper the dealer cannot see any tell tale signs of anything.
Old 04-17-2016, 12:30 AM
fresnobrianb's Avatar
2005 C230
Iceman care to share your installers info? I'm in the Central Valley so it's either LA or the Bay in order for me to find someone to put this thing on.
Old 04-17-2016, 01:11 AM
Iceman II's Avatar
I'm south of Riverside so this might be quite a drive for you. Here is a link to the shop website -- family owned. Ask for Erik.
http://www.autohausfrankfurt.com/performance/#&panel1-2
Old 04-17-2016, 07:09 AM
Former Vendor of MBWorld
Team@Rebellion's Avatar
E63 AMG
Hi All,
Glad you are getting them installed, as per our recommendation professional install would be best as it is tricky to get into the sensors. That said it can be done at home just make sure you have plenty of time and a selection of tools at your disposal.
Due to the layout of the 63 engine access is difficult and there is no easy way to get to the boost sensors along the front, the best way I have found is using smaller flat head screw drivers to release the clips and another to gently leaver the clip off.
We have installed these at customers houses with limited tools so patience is your friend on this one.
Ill keep an eye on my mails if there are any specific questions please just fire them over to info@rebellionautomotive.co.uk
Cheers,
Matt
Old 04-17-2016, 08:34 AM
CT-AMG's Avatar
AMG C63S
Matt: Where does Rebellion recommend to put the module.
Old 04-17-2016, 11:52 AM
Equake's Avatar
2015 C63S
Getting mine installed tomorrow. I will let everyone know how it goes.
Old 04-18-2016, 04:42 AM
E63 AMG
Hi Guys,
We usually mount it just under the lip behind the headlight but the unit is water and heat proof (not direct turbo heat lol) so it is pretty hardy.
I will grab some pictures today for you.
Old 04-18-2016, 07:12 AM
RDO247's Avatar
C63S
Can some one post a step by step filter swap...
Old 04-18-2016, 09:40 AM
CT-AMG's Avatar
AMG C63S
They are underneath the 2 large AMG black plastic pieces. I didn't personally change them but, they pop out fairly easily. Sorry, I don't have any pics or video for you but, the filters are fairly simple to swap out..
Old 04-18-2016, 10:59 AM
bgm130's Avatar
2016 C63S
Ok i hope this picture works. did a quick edit on an engine pic I had.
first make sure the engine is cool. the clamp on the turbo get HOT
next you will have to remove the cap where the red arrows are. there is a clip on the back you push towards the front of the car to release it. inside you will find a sensor clips. first pull out on the white locking pin and then you should be able to un-clip the sensors.
next you want to use a torque bit and remove the remove the 4 screws per side (green arrows)
lastly you loosen the pipe clamps (yellow) and you should be able to lift the cover up and out.
make sure when putting back together you attached the pipe to the turbo fist you want to make sure that is in snug. then tighten the 4 screws. the 4 screws on each side make sure to tighten well. as that will pull the intake box together to create a seal.
you can see what it looks like with the covers removed
Old 04-18-2016, 12:41 PM
Equake's Avatar
2015 C63S
Just got it installed. Here is where they mounted the module.
Old 04-18-2016, 05:38 PM
RDO247's Avatar
C63S
Does the mesh on the new filters go up or down? Rebellion print up or down?
Old 04-19-2016, 03:07 AM
hamish05064's Avatar
BMW
thanks for the share, they look nice
Old 04-19-2016, 03:18 AM
RDO247's Avatar
C63S
Factory vs Rebellion filters
Old 04-19-2016, 03:21 AM
RDO247's Avatar
C63S
Old 04-20-2016, 08:01 AM
E63 AMG
Hi Guys,
When Im installing I personally mount the kit under here (see below) for RHD cars and for LHD(US SPEC) I mount on the other side.
That said as long as it is not indirect contact with excess heat it will be fine
Old 04-20-2016, 08:17 AM
RDO247's Avatar
C63S
Originally Posted by Team@Rebellion
Hi Guys,
Can you add to the above picture where each sensor is located and where you ran the harness for each sensor for a right hand drive car.
Just realised that most guys who posted install info are in the US.
Photos of each sensor with factory harness attached and disconnected would be handy to save on guessing.
Old 04-20-2016, 08:31 AM
PorGT3's Avatar
W205 c63S estate, 997 GT3, 981S
+1 for RHD pics and sensor plugs pics. Thanks.
Old 04-20-2016, 09:11 AM
E63 AMG
No worries ill start getting some pictures together.
Pic below shows what the sensors look like under the cover.
You have already rated this thread Rating: Thread Rating: 1 votes, 3.00 average.
Quick Reply: Rebellion Piggy Back Installation Thread..
