Mode Carbon Product Showcase - Featured Item: C63(S) Edition 1 Front Splitter
Former Vendor of MBWorld
E90 M3, F80 M3, C63 507, F90 M5
We are proud to introduce the latest offering in our W205 C63(S) Collection: the Mode Carbon Edition 1 Front Splitter. Incorporating styling cues from Affalterbach, our Edition 1 Front Splitter turns your C63(S) into an untamed DTM-inspired beast without sacrificing daily drivability. Our 3 piece design protrudes outward from the front bumper, as opposed to sitting underneath it, thus preserving your ground clearance and allowing for a better approach angle. Street presence is off the charts with this one, adding a sinister front personality to match the racket coming from the spooling twin turbos. The left lane is all yours, and they will move out of your way.
Installation:
The Edition 1 Front Splitter installs via both screws and 3M double sided tape. It utilizes all of the OEM mounting points on the front bumper, so there will be no drilling to the bumper required whatsoever. Hardware simply bolts up to the existing holes in place. Professional installation recommended.
Technology:
At Mode Carbon, our manufacturing process takes full advantage of a dry-layup vacuum infusion process. This allows for less resin to be used in between the carbon fibers, creating a dramatic weight advantage.
The vacuum infusion technology of our process also ensures a perfectly even distribution of the resin. The result is a pin-straight weave pattern, which generates a more consistent level of structural integrity to maximize the overall rigidity of our carbon fiber products.
100% Carbon Fiber:
All raw materials used in our manufacturing are hand-picked from Germany, France and Japan to ensure that our carbon fiber products exceed even the most strict industry standard of quality.
The carbon fiber is finished with UV protected clear coat to prevent discoloration from sun exposure. The glossy finish not only provides stunning aesthetics, but also serves to maximize the longevity of our products by increasing their durability to the elements.
The Result:
Our commitment to quality is high-grade carbon fiber that reduces weight, increases performance and improves aerodynamics. Whether your car is for the street or dedicated to track use, Mode Carbon products offer an ample blend of quality, refinement and style.
Advantages:
• Vacuum Infusion Technology
• Superior Stiffness
• Weight Reduction
• Improved Aerodynamics
• UV-Protection
• High Gloss Finish
• Pin-Straight Weave
Installation:
Technology:
100% Carbon Fiber:
The Result:
Advantages:
• Weight Reduction
• UV-Protection
• High Gloss Finish
Love it! Can u PM price for splitter by itself and all 3 pieces together (rear diffuser, front lip and splitter)? Thanks in advance!
Terry 45 (07-05-2016)
Likewise Matt! Your Edition 1 is going to look bananas when you are all done with her.
Thanks for the template
Thanks for assisting with putting this monster together.
Euro-Spec Front Lip Kit and Euro-Spec Rear Diffuser
