Another tuning thread for the Biturbo V12
Alright, I'm trying to decide if I should at some point put a tune on the car. This is less about overall power output and more about removing that pesky limiter. My concern, however, is that nearly all the tunes I see add 100hp and 100lb/ft or more, which makes me wonder about reliability. The car is already around 600lb/ft, how much more can it take before parts start coming out the back? Anybody here been living long term with a tuned twin turbo? All I can find on reliability is don't run it with slicks at the track and Eurocharged tunes on the supercharged AMG's seem to starve cylinder 8. Eurocharged does offer the best value, but Renntech offers a plug in tune you can take on and off at your leisure. How much do these tunes affect day to day driveability and fuel economy?
I plan on taking the Dodge to Bonneville next year, and it would be nice to have the Mercedes tuned up a bit and delimited, although I don't know how much I like moving the rev limiter...
Any input or experience would be very much appreciated. I've done research but most the information I found was from people with a fresh tune, not those who have lived with it for a while.
The Eurocharged tune is also re-flashable yourself any time you want. You shouldn't need to worry about reliability at only 100hp extra...these cars are still only putting out 50hp per cylinder with a tune, which is a joke. Tons of cars do that stock. I don't usually start to worry about eating engine parts until I get up around 100hp per cylinder. My tune has only been on the car a year, but no problems apart from having to replace one coil (which was due with 90,000 miles on an original coil anyway).
The transmission/driveline is what you'd have to worry about...and mostly only would have problems like you said if launching hard with lots of traction and sticky tires.
As far as day to day drivability and economy, I saw no difference in highway MPG. I think the throttle response (at least in sport mode) is a lot better after the tune. I really like the way it drives with the tune, the sloppy throttle response when it was stock always bugged me. I have both the ECU and TCU tunes.
If you are more interested in removing/increasing the limiter see if you have someone near you with Star and they can change it for you.
With that said, I have the Eurocharged tune on my SL63 and really like the difference it made.
What is it about the tune that takes out the coils and inverter? Any way to protect them? Habitually, I have a pretty relaxed driving style, easy off the line and easy around corners. I like to save the full throttle runs for the opportune moment and go right back to driving Miss Daisy. On rare occasion, I would go to the drag track with it, just to mess with the Camaro and Mustang crowd.
For my purposes, this may be the better option. Will it remove it entirely or will the 187 limiter still be in place, as Car and Driver found when they tried to max a CL55 that Mercedes said they removed the limiter for.
Star can raise it, I bumped mine to the 155 limit most MB's have using star, I believe there is another option to remove it totally but I would have to experiment as it's all in german. I tried one of the several "no limit" options and it moved the limiter to 100mph.
Is your problem the top speed limit, or the transmission torque limit that occasionally causes limp mode after a hard run?
I've never heard of this torque limit and limp mode. What's the behavior that to look for? The top speed limit is my primary concern for a Bonneville run, but extra power would be nice. I don't want to start burning through components, though, just for the odd occasion I do plant my foot.
Top speed runs can be extremely hard on cars, stock or otherwise. I mean you're essentially wide open throttle for MILES. That's obviously going to be a lot more stressful on things than the few seconds of WOT accel you can get away with on the street (before you're doing 100+), or even the 10 seconds or so during a drag race (the only really rough part there is the launch). If you're really worried about breaking things, I wouldn't recommend you go do 5 miles straight at wide open throttle.
Good luck actually catching them in-stock though. I had Oreilly's trying to get me one for over a month before I gave up and went through FCP euro. I can't imagine how long you'd be down if there was a warranty problem.
Still very much a work in progress. We drove the car last night, though- so that's cool.
V12 Running on Plug n' Play ECU - YouTube
Gotcha. In other words, everything is still theoretical but the proof of concept works. This will be a big deal if it works and is priced not too out of line with stock replacements. Keep us posted.
From what I've read it tops out at 186 (300kph) as you've suggested. I've only used star on my SL63 so far and it has the tune (limiter removed) so I haven't tested it conclusively. I can play around with one of my other cars on Sunday and see if the 186 max is truly the case.
