FS: (SoCal) 190e 2.3-16, some assembly required
86 930, 86 2.3-16
Unfortunate circumstances are forcing me to sell this project before it is completed since I will no longer have the space or facilities to finish it. It is a great project that really just needs to be assembled at this point. The car is straight with no rust (arizona car), but needs paint. It has 225k on the odo. Body kit is 100% there with all covers and everything, and it has a set of depo headlights. Interior is salvageable with the exception of the drivers seat which needs reupholstering. The dash has no cracks. Gauges are all there as well. I bought it with a blown head gasket, and when I took the head off I wasnt happy with the condition of the bores so pulled the engine for a full rebuild. Had custom Arias 12:1 pistons made up, and picked up a set of 2.5-16 cams for the 1mm extra lift. I have virtually all the parts for the engine rebuild, including bearings, gaskets, new water pump etc etc. Im sure there are a few gaskets here and there that I missed, but for the most part it is ready for assembly. I had the block bored over 0.5mm to 96mm to match the pistons and the head was checked and given the ok. Pistons are already hung on the stock rods. I would prefer to sell it all together, since the numbers match and everything, but if that doesnt happen i'll look into parting everything out.
$4500
I also have another disassembled engine and another set of arias pistons available
$4500
