w204 C63 AMG Coupe 983 HP 5.5 V8 BiTurbo 4Matic?????
'11 C63 P31, '06 Infiniti G35 Sedan (sold), '03 Nissan 350Z (R.I.P.), '15 Toyota Hylander
Wow! That sure sounds like a 5.5L... and it goes like h-e-double-hockey-sticks! :0
Too bad he doesn't do a real, hard launch at any point.
chrisridebike8 (07-21-2016)
^^^"race" that Supra got walked like a golden retriever!
That is an insanely fast Merc.
Epic build. Engine swop, transmission swop, must have taken a lot of effort to get everything to work.
This car has a rebuilt engine with a bigger displacement 5.8, it has a GAD upgraded turbos just like the one Vasilly has on his car which are only offered with a stronger rebuilt engine, it has top mounter GAD intercoolers, rebuilt transmission, it has a full fuel system upgrade low pressure and high pressure, with race gas! and mathinol this car should be capable of having hp1200+ on the crank
This Modified Mercedes-Benz is a Real GADass
Mad scientists try to swap the minds of chickens and humans. GAD scientists, the engineers and technicians at the German tuning firm GAD-Motors, make the "C' in "C63" stand for "Crazy."
Read the rest on the MBWorld.org homepage. >>
How do I get my '07 SL55 to sound like that?
That is beautiful....
My '07 SL55 has the factory Performance Exhaust and local Benz owners say it sounds pretty good, but I want to hear the 'crackle' on deceleration. Any suggestions?
Try the easiest thing first though: remove the muffler and weld a straight pipe in place. If that doesn't work, then try removing the catalytic converter as well, and weld a straight pipe in its place. An aggressive tune might make the car run a bit lean as soon as you lift off the throttle, which can cause crackle sounds.
You can always weld the original parts back on if you're not happy or if you could not achieve the sound that you want, and you want to go back to stock.
