For those with Weistec S/C and meth
For those with Weistec SC and meth, (1) how much did the meth help in reducing IATs? (2) You installed the meth nozzle in the Weistec intake - at that plug location in the intake bend? and (3) What meth vendor kit did you use? Thanks for any help or response.
1) no help at all
2) yes
3) Devils Own
I use meth simply to help compensate for out substandard fuel. Mine is set up to spray conservatively otherwise the AFRs will dip too much
2) yes
3) Devils Own
Do you know if it is possible to move the nozzle to one of the two holes/opening by the map sensor on the weistec intercooler...you think that would then lower IATs?
I don't know. When I had mine installed, I made enquiries with some of the more knowledgeable forum members about nozzle location and followed their advice. If you find a way to use meth to improve IATs, I'd be keen to know about it
You know I don't have the Weistec, but I would imagine there's a similar location as SneakyNeon's that could be used on your setup: right after the intercooler across from the MAP sensor. Mayhaps a bit downstream of the MAP if possible.
Personally I wouldn't touch a Devil's Own kit, the injection method and failsafes on the Aquamist are far superior. With HFS-3 I consistently see IAT's well below ambient when it is injecting. Take out a point of fuel or so depending on W/M ratio and you are good to go.
Those are my two copper.
Yes, but given Weistecs configuration, I have not been able to find that similar location.
The Allen bolt caps for those two opening are 1/8 NPT, the same as meth nozzles, and looks like the same thread pitch.
Anybody thought about a metal spacer between the intercooler and Weistec sc, like 1/2 or 1 inch, so that you can have ports in that spacer for meth nozzle?
Max.H (12-19-2016)
No real IAT benefit for me but fattened the hell out of the top end mixture.
P'S. My IATs on the dyno were 101-139. I expected it to run hotter. KC/no HE/ trunk tank and meth
I'll be the guinea pig for putting the meth nozzle by the MAP sensor. We used one of those ports to read boost on the dyno. I will keep you informed.
I see some reduction in iat spraying pre blower in the supercharger inlet with dual nozzles and 50/50 meth
rawdvm (12-20-2016)
