C63 AMG (W204) 2008 - 2015
High Idle in Park normal in gear?
Old 07-22-2016, 11:20 PM
dreilly36's Avatar
c63 amg
Today my c63 started idling higher in Park
It fluctuates between 1000-1500 Rpm
When I shift into gear it's normal. Any suggestions or clue why this is happening?
P31 with 82k Mikes power pipe
Old 07-22-2016, 11:49 PM
Jasonoff's Avatar
Received 1,576 Likes on 929 Posts
2010 C63 AMG
In gear it's under load. Could be, TPS, vacuum leak, ICV...
Old 07-23-2016, 01:56 AM
dreilly36's Avatar
c63 amg
yeah i think its a vacuum leake. i have a cel on for a purge valve and i can hear a whistling sound in the engine bay.
Old 07-23-2016, 12:18 PM
Jasonoff's Avatar
2010 C63 AMG
That was some vital information you left out of your first post. Just sayin'
The following 2 users liked this post by Jasonoff:
ENV˛ (07-24-2016), ZephyrAMG (07-23-2016)
Old 07-23-2016, 11:04 PM
dreilly36's Avatar
c63 amg
Ran the codes p0171, p0174, p2187, p2189. Definitely has an audible whistling sound coming from engine. Gonna take it to dealer Monday
Old 07-24-2016, 10:33 AM
Jasonoff's Avatar
2010 C63 AMG
Hopefully not, but could also be a crack in your IM considering those codes. Have you checked if any of the bolts are loose. All of mine were, didn't have any codes but I re-torqued them anyway.
Old 07-26-2016, 12:25 AM
dreilly36's Avatar
c63 amg
i called a couple indy dealers and they told me to pull the oil cap with engine running to diagnose the problem. i did and the whistle went away and motor rpm went down. thought that would be pretty obvious. he said that would confirm the PCV valve.
called mercedes and they said its $160. emailed parts.com and they have it for $90
Quick Reply: High Idle in Park normal in gear?
