C-Class (W202) 1995-2000: C 200 CDI, C 220 CDI, C 270 CDI, C 180, C 200 K,C 230 K, C 220, C230, C 280
Shifter won't stay in drive
Old 07-25-2016, 02:20 AM
Ali Ramazhan's Avatar
1999 mercedes c230k
99 c230k and my car shifter slides up to neutral. I have to usually just hold the shifter back in drive the whole time because it would go up at anytime there is this little space between neutral and drive that the shifter always goes in to which cause it to not drive and act like it's in neutral all other gear spots are tight and not loose like the drive gear .
Suggestions?
Old 07-25-2016, 11:38 AM
Plutoe's Avatar
1999 E300TD
Sounds like you have a worn shifter bushing-----put the car on a lift and look up----wada you see
Old 07-25-2016, 08:22 PM
1999 mercedes c230k
i checked the bushing and they seemed fine i had the gear shifter tooken out and nothing wrong with the bushing.
Old 07-26-2016, 06:57 AM
Plutoe's Avatar
1999 E300TD
Very starnge,you don't need to take the shifter out to examine the bushing or make shift rod adjustments---that's all done from below!!
Old 07-27-2016, 02:31 PM
1999 mercedes c230k
Is there any other things I can look at ?
Quick Reply: Shifter won't stay in drive
