New Member - looking for pointers
1986 Carrera 3.2, 2015 GTI, 2000 ML320
Hi all,
New member to this section of the forum. Formerly had an SLK32 AMG, sold it, and bought a 1986 Carrera. Just picked up an ML320 from 2000 as a DD and it needs some TLC.
There's a coolant leak somewhere, I'm thinking the reservoir, and none of the brake lights work, which I'm assuming is the brake light switch.
What are some other problem things I should look out for? Appreciate any tips as well on what the best shop manual is.
Porsche has a few with great pictures, hoping someone can steer me in the right direction here.
To find a leak in the cooling system, you should have it pressure tested at 20psi.
For the Brake Lights problem, you will need a test light.
Remove the cover under the Instrument Panel and access the BL Switch. Turn the key to pos. #2 and test the following wires:
Without touching the Brake Pedal, GREY & WHITE-test light should illuminate.
Manually push down on the Brake Pedal, BLUE wire-test light should illuminate. If the BLUE wire does not illuminate, you need a new BL Sw.
What does CP mean? Stop using abbreviations only you know what they mean.
Yes you can use a volt meter if you have three hands.
kyngfish (07-26-2016)
