LAKIS1961
LAKIS1961
I own a CLK200 W209 2007 and I have a problem with the multi-contour seat,the air controls that adjust the seat shape for your back,legs,etc.
It used to work for the first 4-5 presses of the knobs but now it doesn't work
at all.I checked the small pipes and they fit ok,also the fuses are ok.The problem is the same for both front seats.
Any help will be appreciated,i suppose there must be an air pump somewhere if anyone knows where.
Regards
LAKIS
Regards
LAKIS
Thanks for the reply Rodney,could you be more specific [what is the firewall]and where is situated. Also can you tell me where is the vacuum pump situated so that I can check it.
Regards
LAKIS
Regards
LAKIS
LAKIS1961 (07-28-2016)
OK, I need to stop using crack. I would have bet $10,000 of someone else's money that we have previously discussed the location of the air pump - and it was some fellow named Rodney who told us where it was. But if there is not one, then I'm very curious - how does vacuum inflate a bag?
MBworld Guru
Well, thanks, Yidney for keeping me honest (or at least from going totally senile!) I keep getting my models confused. Years ago, many models use engine vacuum for the seat bladders. They still use it for lowering the headrests on some models (W203, W209 coupe) and door locks and trunk closers (CL, SL, S) but the seats are operated by an electric air pump:
http://benzbits.com/w209/AirPumpForSeats.pdf
MBworld Guru
Yeah, it probably is in a slightly different location on the cabriolet. StarFinder has no photos of it (and FYI, it's part M40 not M33 as indicated in that WIS doc - M33 is the secondary air pump on the engine). EPC doesn't show anything more, either, except from the appearance of the vacuum lines, it would be on the left side of the trunk. Happy hunting!
