Auto dim side mirror delete
Old 07-27-2016, 10:07 AM
eteller's Avatar
2009 CLK 350
Ok so my driver's side mirror on my 2009 CLK350 is starting to get hazy at the top. I just want to replace this with a non-auto dimming mirror, heated would be nice. I do not want to tack a piece of glass on top as the alien blood inside can still leak. Does anyone know of a good source for the mirror and backing and also is the mirror after the face lift different? I found several sellers on ebay from Latvia, but their description is lacking.
Has anyone removed the auto dimming part without hacking the mirror to hell? I hear there is a mirror under the auto dimming part.
Old 07-27-2016, 08:06 PM
koolavz's Avatar
Mine is starting to go as well. I was looking at the ebay replacements, wasn't sure about them either. Hopefully someone can shed some light on the subject.
Old 07-27-2016, 09:06 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
The dimming features uses and LCD panel built onto the glass. When it dies, you need a whole new mirror glass. If you want to forgo the dimming feature, you can install a less expensive plain glass.
Old 07-27-2016, 10:28 PM
eteller's Avatar
2009 CLK 350
Rodney, I got that but is there a part#?
Old 07-28-2016, 05:58 AM
DanielFD's Avatar
2007 BMW 550i
all the clk mirrors are heated. No reason for a part number and no change between facelift and non facelift. Just search for a w209 mirror
Old 07-28-2016, 09:24 AM
eteller's Avatar
2009 CLK 350
Looks like this will do it, no more toxic paint eating alien blood to deal with:
http://www.ebay.com/itm/513LFH-Merce...ZUfjcX&vxp=mtr
I searched 'mercedes clk mirror glass' and got better results than my previous search.
Old 07-28-2016, 09:25 AM
koolavz's Avatar
I may have to order that, if you buy it please let us know how hard it was to replace with your old one!
Old 07-28-2016, 12:14 PM
eteller's Avatar
2009 CLK 350
I did have to pull the mirror glass on the passenger side to do the turn signal lens. As I recall removal is the easy part, getting it back on was a PITA.
Old 07-28-2016, 01:01 PM
waveterrorist's Avatar
Firemist O5 CLK55 Cab Silver 05 CLK55 Coupe Tanzanite 06 CLK500 Coupe
After the mirror is wired up installation should literally take 10 seconds...
Old 07-28-2016, 04:49 PM
mbarney's Avatar
2010 GL 450, 2004 CLK 500
I just got one of those. My 2004 CLK 500 has a plastic trim piece around the mirror so I am going to try and trim the mirror down. If it was not for that piece of plastic it would probably fit fine. I am not the original owner of the car so I don't know if the mirror has been replaced.
Mike
Old 07-30-2016, 08:06 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
Mine went bad as well and the auto-dimming ones are very expensive. So I opted for a non-dimming and bought one from a forum member on here and it even was the euro style one with the curve at the end. They are all heated (have 2 pins that need to be connected), only different is it is missing the big plug where the auto dim feature would snap into. With the windows tinted, I don't get much glare in almost all circumstances.
Old 07-31-2016, 03:27 PM
sailorben's Avatar
CLK W209
My driver's side mirror on both CLKs I have had had a black bit of plastic/ rubber around the edge. But not on the passenger side.
Old 07-31-2016, 05:04 PM
gaazmon's Avatar
i think that plastic is on the auto dimming mirrors to keep the fluid sealed or something. the non-dimming one i have now does not have it.
Old 08-01-2016, 03:51 AM
DanielFD's Avatar
2007 BMW 550i
Thats right, mirrors with that plastic on the edge means its an auto-dimming mirror. Mercs dont put auto-dimming mirrors on the opposite side of the driver. Guess you could say its a safety thing. My BMW has both mirrors that dim, and not a security issue at all.. just less glare.
Old 08-01-2016, 12:26 PM
ALFAitalia's Avatar
Alfa 159
Deleted....posting with brain not engaged!
Quick Reply: Auto dim side mirror delete
