How to manually pump air into air tank???
About to pick up this e55 amg its no start, i would like to know if i can manually pump air and raise the suspenison to load it on my trailer
Help please
Help please
'99 and '05 E55 AMG
Without the diagnostic system, you're looking at a long, hard slog.
Originally Posted by bbirdwell
If the battery has a good charge, you can connect a DAS Xentry and manually activate the pump and air spring solenoids even with the engine off. That feature is used whenever the air bags are replaced or the suspension calibrated.
'99 and '05 E55 AMG
It is required if you expect to work on any Mercedes with a distributed micro-controller system operating over a CANBUS. If none of the above makes sense, start teaching yourself.
Search on "DAS Xentry Mercedes".
Start here for 42 pages of tips:
https://mbworld.org/forums/w211-amg/...ts-o-pics.html
Assuming you can locate access or obtain a DAS, you'll need to go to "Control Units", "Chassis", "Airmatic" and follow the instructions to inflate the air springs.
