Voice Command Question - can you help?
Old 08-19-2016, 07:02 PM
Mandingo's Avatar
W222 S63 AMG
I know I should know this but ...
Voice commands for navigation - I can get all types of destinations input via voice except the type I use most often (Memory).
Navigate to a POI - easy, just say "POI".
Navigate to a new address - easy, just say "Input destination"
BUT ... how do I get it to show me a list of my saved memory destinations?
These are obviously the ones I use the most (hence why I saved them) but I can't find the voice command to select one of those from the list.
Note I am not talking about "voice tags" where you record your voice, I am talking about just showing a list of saved locations on the screen, just like it already does for POI's.
I'm confused, can you help?
Old 08-20-2016, 04:11 PM
konigstiger's Avatar
Received 4,415 Likes on 3,145 Posts
'71 Pinto
Try "List Destination Memory"
Old 08-20-2016, 04:31 PM
Mandingo's Avatar
W222 S63 AMG
Thanks but that's voice tags you have recorded, not the list of saved destinations "From Memory".
Old 08-20-2016, 04:39 PM
Mandingo's Avatar
W222 S63 AMG
I think the closest I can get is "Last Destinations" and hope the one I want is somewhere in my recent list.
Basically what I want isn't possible without recording an audio tag for every address in the list (no thanks). Kind of a bad omission for the voice team.
Old 08-23-2016, 10:39 AM
adf111's Avatar
2007 S550 Designo Edition
Check this:
Attached Thumbnails Voice Command Question - can you help?-memory-voice-command.jpg
Old 08-23-2016, 10:45 AM
Mandingo's Avatar
W222 S63 AMG
Originally Posted by adf111
Check this:
Yeah, thanks but that's Voice Tag again. It requires you to make a voice recording for every entry. It also involves having to input the addresses again a second time. I have 42 saved addresses.
What I wanted was just to see the existing list and pick one from there using the same method as POI's where it shows them as a numbered list and you just say "Number 4" and you're done.
Old 08-23-2016, 04:57 PM
DaveW68's Avatar
Location: Land of Political Criminals and Urban Shootings
2015 S550
You're working with technology from 2005 and earlier. I think you're expecting way too much. I've had my car for almost 2 years and I don't think I've ever used my voice command. Hell....I think I've only plugged an address into my nav once over all that time, just to see how it works. Perhaps it's because I'm a man, but I don't need to rely on an archaic system to get me from place to place.
I think you need some good memory training if you need help getting to places that you've previously visited.
Old 08-23-2016, 09:07 PM
Mandingo's Avatar
W222 S63 AMG
Thanks Dave, your post was helpful and right on topic.
You're a special guy and I hope all your fellow inmates appreciate how special you are.
Old 08-23-2016, 09:36 PM
DaveW68's Avatar
2015 S550
Can you believe that they let me lug my laptop around all day in prison? Minimum security rocks!
Old 08-26-2016, 03:05 PM
fbracer's Avatar
11 S550 4MATIC
I'll bring you some cigarettes and clean underwear
Old 08-26-2016, 07:09 PM
DaveW68's Avatar
2015 S550
Much appreciated!
Old 09-09-2016, 05:57 PM
adf111's Avatar
FOUND IT!!!
Mandingo, Actually, I just found the way to do it yesterday.
Start with Phone > Data/Connections > Address Book.
It'll show a list of the vehicle's address book.
Push "mouse" forward and select the first entry.
It'll show the address entered but will also have OPTIONS to the right, and BACK to the left.
Go to Options > Voice Name> Add.
It'll ask you to record the tag twice, will let you listen to it and then store it.
Go back to the next on the list, and add 42 different tags to your 42 addresses.
Once recorded, you can always go back, but instead of ADD, you see CHANGE or DELETE...
A friend watched me doing it and said: "Had my car had this feature, I'd tag my ex as THE B...CH, and then just press the voice command and say Navigate To The B....".
Enjoy!
Quick Reply: Voice Command Question - can you help?
