The side mirror hit the door.
Old 08-21-2016, 02:00 AM
Hailey's Avatar
2008 ml350 (w164)
When my vehicle close the right side mirror, it hit the door.
Can I repair it?
Do I have to replace the assy?
Old 08-25-2016, 03:02 PM
bha
bha's Avatar
13 GL350, 14 SL550
Mine does it too (on the drivers side)
someone with a GL told me his does, and I said "no, my truck never does it". Then I looked at my truck the next day and there was a scratch!
If you look at the top crease on your odor, there is a scratch/scuff and that is from the mirror touching the door. When you park it in wind, it moves the mirror back and forth against the door and scratches it.
They all do it from what I can tell, some worse than others. All you can do is disable the folding mirrors (it's in the instrucment cluster settings menu)
Old 08-26-2016, 02:26 AM
Hailey's Avatar
2008 ml350 (w164)
Thanks.
I think the origin of the problem is meshing of the gears.
I hope to get the deal drawing...
Old 08-28-2016, 06:59 AM
Hailey's Avatar
2008 ml350 (w164)
pict
Old 12-30-2017, 04:04 PM
lkchris's Avatar
'07 GL320CDI, '10 CL550
There is a Mercedes tech bulletin on this.
The solution is to replace the mirror internal mechanism (keep your glass and cover)
Old 12-30-2017, 05:42 PM
Hailey's Avatar
2008 ml350 (w164)
Could you tell me the parts number?
Quick Reply: The side mirror hit the door.
