C63 AMG (W204) 2008 - 2015
▀▄▀▄ Vivid Racing | Agency Power C63 AMG Performance *IN STOCK*
Old 08-24-2016, 01:52 PM
Former Vendor of MBWorld
VividRacing's Avatar
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
Vivid Racing Presents: Agency Power Performance products IN STOCK ready to ship
MSRP Listed Below. PM, call, or email for FORUM Exclusive Pricing!
Aohare@vividracing.com | +1.480.966.3040 x230 | www.vividracing.com
We have some of the very best products for the C63 AMG in stock and ready to be sent at a moments notice. After going through our inventory, we have literally found the entire line of Agency Power C63 parts that we need to sell. Feel free to message me for more information!
List of Items for sale:
Agency Power Carbon Fiber Front Lip Mercedes Benz C-Class W204 AMG C63 08-10 MSRP $995
Transform the look of your Mercedes-Benz C63 AMG with this Agency Power 2×2 Carbon Fiber Front Lip Spoiler. Made from high quality 2×2 carbon fiber weave and has been finished in a beautiful 3K UV resistant gloss finish. This Agency Power Front Lip is simple add-on that will add aggressive styling to the front of the C63 AMG. Designed to fit the stock 2008-2010 C63 AMG front bumper.
Features:
Aggressive Styling
Carbon Fiber
2×2 Carbon weave
High Gloss Finish
3K UV resistant
Agency Power Front + rear Adjustable Sway Bar Endlinks Mercedes-Benz C63 08-14 MSRP $225
When setting up the suspension on your Mercedes Benz, being able to dial in a good corner balance and weight alignment will give you the best handling possible. As well, when you are upgrading suspension components, getting rid of any rubber bushings or ball joints for spherical bearings will enhance the vehicles response. The front sway bar is under a lot of force and when properly setup, the stiffness of the bar can take a great toll on the factory sway bar links.
Agency Power has released these adjustable front sway bar links for the Mercedes Benz C63 AMG. The sway bar link features a CNC machined aluminum turn buckle that has a slight bend for clearance purposes. The piece is anodized in Black and then laser engraved with the AP logo. The precision machined part features spherical rod ends on either side with opposite threads for on the fly adjustments. The 3 piece Teflon lined rod ends include CNC machined steel spacers which fit factory mounting points. Both of these pieces are done in a black oxide finish to protect themselves from the weather elements.
These sway bar links fit with most aftermarket sway bars and coilover setups. They are sold as a pair and include everything needed for installation.
Agency Power Under Drive Crank Pulley Mercedes- Benz C63 AMG 6.2L 08-14 MSRP $600
The Mercedes Benz C63 AMG is a beast already with its V8 stuffed into the small C-Series chassis. Making 450 horsepower stock, this car is no slouch. But with the help of Agency Power, we can improve throttle response, horsepower, and torque with our under drive crank pulley. How is this accomplished? This is done easily using precision CNC machining and detailed CAD design to create a pulley that is lighter weight and underdriven. Rotational weight typically has a factor of 3. Even the smallest static weight can have improvements. When the pulley is lighter, the engine crank does not have to turn as hard. When we also make the pulley a smaller diameter the engine pumps out even more power because of the pulley size. The new Agency Power under drive crank pulley is made of high strength 4140 Steel with an Anodized Aluminum outer ring for a sleek OEM look. This pulley uses a rubber core to ensure proper engine harmonics and dampen vibration. The diameter is 15% smaller than the OEM pulley with weight saving of 1.3 lbs over stock. The acceleration gains are apparent immediately. The kit includes new belt and new crankshaft bolt. Pair this pulley with our tuning, header, and exhaust system for optimal results!
Features:
Improved Throttle Response
Improved Horsepower and Torque
Approximate Gains: 10-20hp & 10-15ft/lbs
CNC Machining
Lighter Weight
High Strength 4140 Steel
Anodized Aluminum Outer Ring
Rubber Core
15% Smaller
Weight Saving of 1.3lbs
Included:
New Belt
New Crankshaft Bolt
Agency Power Electronic Valve Controlled Exhaust Muffler Mercedes-Benz C63 AMG $2800
Agency Power Mercedes C63 AMG Electronic Valve Controlled Exhaust System
Agency Power set out to produce the best exhaust system to appeal to the entire market. The solution is simple, create a high performance, quality built product with variable exhaust sound and performance. Aggressive when you want it, quiet when you don’t.
The Agency Power valve controlled exhaust gives the user the ability to control the performance and sound of the exhaust with the push of a button. The high quality dual 2. 75”, TIG welded stainless steel system, is like fitting an OEM component to your vehicle. Including all necessary hardware for fitment, there is no cutting, welding, or adjustment required. The bolt-on system saves a lot of weight off the back end of the car, compared to the bulky stock unit.
At the push of a remote button, a valve opens up on each muffler giving you a race mode with maximum performance. Where other exhausts are always loud, the Agency Power exhaust can be loud only when you want it, giving you a roaring V8 sound, or quiet for smooth city or freeway cruising. With the valves closed, having a conversation, talking on your phone, or listening to music is comfortable. The performance you get from race mode exceeds others systems in sound and quality. With the powerful AMG V8 engine, the Agency Power exhaust extracts an additional 24 rwhp and 16 ft lbs of torque. These gains game from a before and after muffler on our C63 with headers and mid section already installed. If you’re looking for an exhaust that gives you the best of both worlds, then the Agency Power system is the only choice to keep the luxury of the Mercedes C63 AMG along with its race inspired roots all in one package
Included:
Mufflers with Valve System
Electronic Control Box
2 Remotes
Vacuum Lines
Clamps and Gaskets
Agency Power Front Strut Bar Mercedes-Benz C63 AMG | C300 08-14 MSRP $450
A common upgrade among tuners and track enthusiasts alike is a front strut bar. A strut bar mounts between opposing strut towers and reduces the flex that these towers experience during hard cornering. Reducing the flex will keep the wheels in position keeping the tires in the desired position on the road. This will help to improve traction on the turns, increasing turn-in response. A front strut bar will help to reduce under steer and a bar in the rear will help to reduce over steer. We have designed our strut bar to not only look good, but function as well. The Agency Power front strut bar provides just enough flex, without compromising stability.
Features:
Direct Bolt-on Application
Made from 6061 Aluminum
Improves Handling and Cornering
Improve Traction
Improves Engine Bay Looks
Red and Gray Powder Coated Finish
Agency Power Header and Section 1 Mid Pipes Mercedes-Benz C63 AMG 08-11 MSRP $3000
The New Agency Power Mercedes C63 AMG headers fit the 2008 and up model. Made from 304 Stainless Steel, with laser cut flanges for a precision fit. Each header features a 4 into 1 collector with slip in design for easier install. Each runner is 1. 75” with a collector size of 2. 75”. The header kit also includes stainless steel 2. 75” section 1 mid pipes to complete the bolt on installation.
As tested on a 2009 C63 with flash and Agency Power Exhaust on a Mustang Dyno, power was increased 45 wheel horsepower and 42 ft/lbs of torque. In addition to improving performance, the headers also change the tone of your vehicle. Adding a deeper and more exotic sound.
Ordering:
Phone:
You can reach me directly by calling +1.480.966.3040 x230 to place your order over the phone.
Payment Methods:
- Credit/Debit Cards (Visa, MasterCard, Discover, American Express)
- PayPal
- Affirm — Now you can finance your parts!
- Bank Wire
- Bill Me Later
- AZ Orders will incur 7.8% sales tax
- All international orders (outside of US and Canada) require Bank Wire or PayPal
most efficient shipping method takes precedence. Expedited shipping is available by request.
Hours of Operation: We do not observe Daylight Savings Time in Arizona
March-October: M-F 9am-6pm PST
November-February: M-F 8am-5pm PST
We are closed for business Saturday and Sunday
Contact Information:
Phone: 480.966.3040 x230
Email: Aohare@vividracing.com
Website: www.vividracing.com
Please feel free to contact me via PM, Email, or Phone if you have any questions.
Old 08-25-2016, 02:09 PM
bump!
Old 08-25-2016, 10:16 PM
jd_hinks's Avatar
2015 C63 AMG Edition 507 coupe, 2017 Range rover sport Auto, 2008 dodge ram 1500 SLT
"Each header features a 4 into 1 collector with slip in design for easier install."
What is OEM recommendation for sealing slip on runner tubes? Do these have to be welded or hi Temp sealant? or just plug and play? I'M only curious because I have this complete system installed and I'm worried about exhaust leaks. I know a little off topic but Are you able to follow up?
Old 08-26-2016, 12:09 PM
Just to confirm you are saying you have a set of our agency power headers and you just want to confirm what is recommended as far as where the header bolts up to the cylinder head with exhaust flange?
Regards,
Adam O'Hare
Old 08-26-2016, 08:27 PM
jd_hinks's Avatar
Adam,
not the cylinder head and flange that's straightforward. Talking about where the runners slip into the collector. they are not welded and slip in and out freely. Just wondering what you guys recommend to ensure they do not leak after installed. All the headers I have seen are all 1 piece completely welded together. When my mech. installed, he tried to get a hold of someone at AP to find out if Hi temp sealant was needed. Exhaust already installed and enjoying the product. Just curious if sealant or welding is needed to seal the runners to the collectors. Thanx.
Old 08-29-2016, 04:08 PM
subzero05's Avatar
CL500
sexy looking stuff!
Old 08-29-2016, 04:13 PM
Originally Posted by subzero05
sexy looking stuff!
Thanks!
Do you have any questions about the products?
Rate This Thread
Rate This Thread:
Quick Reply: ▀▄▀▄ Vivid Racing | Agency Power C63 AMG Performance *IN STOCK*
