c250 vibration at 2.5k rpm with bms intake
Old 08-24-2016, 08:46 PM
gooey's Avatar
2012 c250
my c250 has recently been vibrating on 4th gear and above between 2.5-3krpms
I removed the bms intake and took the car in for warranty service but the symptoms stopped with the original intake and the dealer couldnt find anything wrong. With the intake back the vibration is back... I swear i feel a loss in power too during the vibration.
anyone have any ideas?
Old 08-27-2016, 12:37 AM
Josh.A.Hussey's Avatar
2017 C43 AMG, 2010 C350 4Matic, 9 Motorcycles
Yes. Is your intake rattling?
Is it ONLY in 4th gear?
Which heat shields are close to the intake?
Old 08-27-2016, 01:21 AM
gooey's Avatar
2012 c250
Thanks for the reply!
The intake is secure it cant move, it doesnt touch anything else.
its 4th gear and above, 1-3 arent affected.
cant take it to dealer obviously as im still under ELW
Old 08-27-2016, 06:17 PM
So if she's in neutral, no noise?
Also, is it RWD or AWD?
Old 08-28-2016, 07:13 PM
Knightmare69's Avatar
2010 C200 CGI
The BMW intake filter was known to rub towards the bottom of the intake box, I'm not sure if they adjusted the filter size since then or if that's the cause of your problem but maybe start from there.
Old 08-28-2016, 11:29 PM
For sure, symptoms really seem like something is rattling that's all. Problem is finding it!
Old 08-28-2016, 11:53 PM
2010 C200 CGI
It's been a while since I had mine installed but I think the problem was towards the bottom of the filter. However, i could also be the filter itself hitting your hood. How far onto the pipe did you install the filter? Try adjusting how far on it's installed. Remember the silicone part of the filter makes it possible to shake around under load.
Old 09-10-2016, 06:00 PM
gooey's Avatar
2012 c250
it sits at least a good centimeter above the nearest surface. and i tightened everything. But maybe i'll try angling it higher a bit more.
Old 09-10-2016, 06:01 PM
gooey's Avatar
2012 c250
no noise in neutral
Quick Reply: c250 vibration at 2.5k rpm with bms intake
