GL Class (X164) 2007-2012: GL320CDI, GL420CDI, GL450, GL550
SRS Error code - 2010 GL450
Old 08-26-2016, 02:26 PM
George Bokas's Avatar
I have an SRS error and with my code reader got the following:
"The opponent or the signal line to the component S68/2 (Front Passenger seat belt buckle and seat belt warning switch) has Open circuit or Resistance too large "
Does anyone know which part this component is or have a diagram for it?
Old 08-27-2016, 06:20 PM
Plutoe's Avatar
1999 E300TD
They are all apart of the buckle system--yours has failed----- purchase a new set for the side that failed--they are all VIN sensitive
Old 08-28-2016, 09:47 PM
thanks!
Old 08-29-2016, 09:26 PM
entersandman's Avatar
W205, X164
Have the exact same issue, but it's sporadic. Local MBZ repair shop says its the buckle. Estimated at $450 for buckle and labor included - additional $200 if the passenger seat had to be taken out to install, as it will need factory re-calibration. So $450 if the buckle is changed without the seat coming off. I'm pretty sure the dealership will have about the same estimates, with an extra '0' in the end.
Quick Reply: SRS Error code - 2010 GL450
