C63/C63S AMG
Tire question
Old 08-28-2016, 12:18 PM
DZ8222's Avatar
C63S
Tire question
Hello!
I'm going to order a set of new rims for my c63s sedan, want to stick with 19" while fitting wider tires then stock 245/265, anyone know whats the widest that can fit without hitting anything? I also want to stick with 35 profile on all wheels. Thanks!
FYI, getting these rims
http://www.nicheroadwheels.com/brush...el-w-25817.htm
Old 08-28-2016, 03:19 PM
SuperNik's Avatar
W205 C63S AMG
It depends on the width of the wheels. I run 255/275 on the standard wheels with no problems.
Old 08-29-2016, 02:11 AM
SBH-'s Avatar
C63S 2016
what I've heard so far is that you can go 255 front and 275 rear with the stock wheels.
do you notice a difference in appearance from the outside? compared to the stock setup.
Old 08-29-2016, 04:22 AM
SuperNik's Avatar
W205 C63S AMG
Not really
Old 08-29-2016, 06:37 AM
DZ8222's Avatar
C63S
Does anyone know the maximum width of the rims that can fit?
Old 08-29-2016, 07:23 AM
Unicorn_'s Avatar
AMG C63S
I've got 245 fronts and 285/35 rears with no issues.
Old 08-30-2016, 12:49 AM
DZ8222's Avatar
C63S
You using stock rims or aftermarket?
Old 08-30-2016, 04:01 AM
Unicorn_'s Avatar
AMG C63S
Stock
Old 08-30-2016, 04:09 AM
SBH-'s Avatar
C63S 2016
with stock wheels you went up to 285 ??
Old 08-30-2016, 09:34 AM
DZ8222's Avatar
C63S
Stock
Do you mind posting a photo please?
Old 09-25-2016, 08:02 AM
SBH-'s Avatar
C63S 2016
+1 please
Old 09-25-2016, 10:53 AM
bgm130's Avatar
2016 C63S
+1 please
guy I know is running 295 toyo R888 on the stock 5 spoke wheels. No issues as far as I know and had them all summer
Old 09-25-2016, 02:28 PM
RDOCA's Avatar
2016 C63S Sedan
Just because he had no issues does not mean they are the correct fit.
With a narrow rim it will pull the tire in and the tread won't be flat on the ground with the correct pressure. Look at the tire rack for the range of tire size with a certain rim width.
I looked and if I remember the max on the 91/2 in stock sedan rim is 285.
It's not just a rub issue.
I saw KING MONKEY put a 305 on custom rims with ? offset and I think 20 in wheels. You can search for his thread as there are pics.
Rate This Thread
Rate This Thread:
Quick Reply: Tire question
