Multi Contour Seat Explosion
Old 09-24-2016, 05:32 PM
OldMerc94's Avatar
2013 ML550 / 1994 E420
Any folks with multicontour seats ever experience a failure of the system resulting in a pop that sounds like a 20oz Coke Bottle exploding?
This happened to me a week ago and I thought a tire popped (it was that loud), and it sounded like it came from the rear driver side wheel well. After looking all around, the compartment for the subwoofer was pushed open - and that is all I can see.
Took me a day to realize the multicontour seats will no longer adjust - but they never lost pressure. So I don't think it was internal to either seat. The pump runs continuously in the back compartment (I unplugged it to keep it from burning out) and the seats no longer adjust.
Really clueless on this one - any one experience a similar issue at any time? Only thing I could imagine is a blown line - but they are all still connected just fine to the pump.
Old 09-25-2016, 05:29 PM
Isawelvis's Avatar
2015 ML350, 2021 BMW X3, 1991 190E
Wow. did this happen in your 550
Old 09-25-2016, 06:21 PM
ItalianJoe1's Avatar
2003 CL 600
Sounds like either one of the connectors failed and the line blew off, or the pressure tank split if there is one (i'm picturing the PSE system on a 215/220, not 100% familiar with yours, but same concept)
We don't see that happen, so i'd be curious as to what you find when you pull it apart.
Old 10-18-2016, 05:49 PM
Rickcls550's Avatar
cls550
Any more info on your seat?
Old 10-27-2016, 02:29 PM
OldMerc94's Avatar
No update yet - I unplugged the power cable from the pump so I could get on the road to Georgia - minor annoyance since I can't adjust the lumbar anymore. Should be going in next month for diagnosis.
Old 01-06-2017, 03:47 PM
OldMerc94's Avatar
Finally got around to getting this fixed - it was the pressure reservoir that stores the air for the multi-contour seats in the rear driver side compartment behind the back seats somewhere. It ruptured and caused the loud pop / explosion sound.
Unexpectedly covered under warranty. Not sure what caused the rupture, but it was definitely a jarring experience.
Old 01-09-2017, 08:55 AM
JDowney's Avatar
2012 Mercedes-Benz S350 BlueTEC 2013 ML350 BlueTEC
Thank god for warranties...
Quick Reply: Multi Contour Seat Explosion
