CL-Class (W215) 2000-2006: CL 500, CL 600
My windows and seats stopped working......
Old 09-27-2016, 11:33 AM
LowKeyCL600's Avatar
2001 Mercedes CL600
Hello group, my windows & seats suddenly stopped working and now my drivers window is stuck partially open so I need advice asap. Would it be the door control module or is there a fuse I can check? Thank you in advance for any insight.
Old 09-27-2016, 01:57 PM
tusabes's Avatar
Mercedes
Probably the door control module
Old 09-28-2016, 07:55 AM
2001 Mercedes CL600
Update, now it's intermittent. Works sometimes, then stops working. Still the control module?
Old 09-28-2016, 12:29 PM
Rob CL's Avatar
E55 AMG | Buell Lightning XB12
I've seen this happen on a few different MB cars from that era. In those circumstances, the issue was cured by simply re-starting the car. Make sure your ignition is off, open the driver door, then start the car again.
Not a permanent fix, but should get you rolling again.
Old 09-30-2016, 04:09 PM
2001 Mercedes CL600
Thank you, I will try that and let you know if it works.
Old 09-30-2016, 08:04 PM
2001 Mercedes CL600
Rob CL, I tried your suggestion, it worked the second time but still not consistent. The passenger window works when the door is opened or closed to seal and unsealed but does not work with the switch to fully open or close. And the drivers side doesn't work at all, not even the seats or mirrors. I think I just might have to go ahead and change the drivers door control unit behind the switch.
Quick Reply: My windows and seats stopped working......
