Tire pressure 2014 ML350 2w confusion
Old 09-29-2016, 05:12 PM
pjw1967's Avatar
2014 ML350 2w, 2017 GLS550, 1967 Pontiac GTO 4 sp
Seems I have 3 choices to use for tire pressure. 2 on the driver's door jamb, and 1 inside on the fuel fill door. What am I missing here? Thanks.
Tire pressure 2014 ML350 2w confusion-20160929_202733654_ios_zpsksuh5bgu.jpg
Tire pressure 2014 ML350 2w confusion-20160929_202758953_ios_zpsu1lvfgnm.jpg
Tire pressure 2014 ML350 2w confusion-20160929_180010006_ios_zpsip66nnew.jpg
Old 09-29-2016, 05:56 PM
Isawelvis's Avatar
2015 ML350, 2021 BMW X3, 1991 190E
Use the last between 32 and 41 PSI. Thats what I use as a reference. I run 36 in all tires.
Old 11-22-2016, 01:13 PM
Cloudbuster's Avatar
14 ML 350 Blue Tec, 11 E 350 Coupe
I had the same issues with both my 2012 & my 2014. I have been running 40 psi in front tires & 42 psi in the rear. Today I just replaced my Continals after 51,711 miles & 4.5 mm still remaining. I rotate tires every 5K miles & also use nitrogen instead of air.
Quick Reply: Tire pressure 2014 ML350 2w confusion
