SL/R231: Active Lane Keeping Assist....Standard or Adaptive?
Has anyone found any difference in the two settings? Which one do you prefer and why? So far I cannot tell any difference but I have not used it much yet. The manual says nothing about how the two settings are different or why the driver would choose one over the other. It just tells you how to switch between the two settings. Thanks.....
Registered User
2013 SL550 / 2006 XK8 / 2013 Triumph Bonneville
Here is the difference between standard vs adaptive
Standard
If Standard is selected, no warning vibration occurs if:
• you switch on the turn signals. In this event, the warnings are suppressed for a certain period of time.
• a driving safety system intervenes, such as ABS, BAS or ESP®.
Adaptive
If Adaptive is selected, no warning vibration occurs if:
• a driving safety system intervenes, e.g.
ABS, BAS or ESP®.
• you accelerate hard, e.g. kickdown.
• you brake hard.
• you steer actively, e.g. swerve to avoid an obstacle or change lanes quickly.
• you cut the corner on a sharp bend.
In order that you are warned only when necessary and in good time if you cross the lane marking, the system recognizes certain conditions and warns you accordingly.
The warning vibration occurs earlier if: • you approach the outer lane marking on a bend.
• the road has very wide lanes, e.g. a highway.
• the system recognizes solid lane markings.
The warning vibration occurs later if: • the road has narrow lanes.
• you cut the corner on a bend.
ho52806 (12-30-2018)
