battery dead and cant get into trunk with laser cut key
2003 E500 W211
hey everyone, i have a w211 E500 and its been sitting for a few weeks and i started it once or twice a week to keep the battery charged but this morning i went to start it and the battery was completely dead, i mean not even a light on the dash. so i tried getting into the trunk with the laser cut key and it wouldnt work. i can turn the key both ways and i hear it clicking like it should open and still nothing. i did some research and found that there was a second battery under the cabin air filter and i tried jumping that and still nothing. i finally gave in and called AAA and they tried sending power to the car through the cigarette lighter and they still got nothing. i am completely out of ideas. can you guys and gals help?
Received 1,467 Likes
The cig lighter isn't active until you turn the key in the ignition so you can't charge it until you do that. Also if you can turn the key in the trunk, you have to lift the handle while the key is turned, you don't just turn the key and then try lifting the handle.
And if you've been to an MB dealer in the last 18 months, you can just call MB roadside assistance for a jump and they'll be able to figure it out for you for free.
Received 1,730 Likes
1922 Ford Model T / no OBD
Yeah, if you qualify - you will get qualified mechanic coming from MB USA road side assistance for free.
Other than that, when you pull lid on fuse box under the hood, you will find power rail on the back of it.
Not enough to run starter on it, but should be enough to supply power to open the trunk, or charge the battery,
The small battery is disconnected from the system when the engine is not running.
I know a fellow who in a similar situation managed to burn thousands of Dollars worth of electronics in his BMW 7 series.
They also have the battery in the trunk and everything is electronic and hi-tech.
He was messing around with cables and heavy duty starting chargers in the middle of winter and managed screw it up pretty good.
Move the jumper in the fuse box
On a W231 the cigar lighter will be dead or alive with engine off depending on the position of a jumper in the fuse block located under the hood. I moved my jumper to the live position to let me easilly connect a battery maintainer when I store the car. You can make the change and then slowly charge your battery the same way or open the trunk. There are many references to where the block is and which jumper to move on the web. That is how I found out about it.
Yes, same on the W211.
Boy, you would think the OP would have figured it out by now and let us know what worked. My guess is that he just didn't know to lift the handle while the key was turned.
great for charging the phone when i run in a store (just wish I had the USB port somewhere less conspicuous).
as for the maintainer, are you using a solar panel for storing or is this for a wall connected device?
2013 ML350 Bluetec
Having a cigarette lighter that turns off when the car is off is annoying. This thread has prompted me to change mine, and in searching for "how to" I came across a good thread:
https://mbworld.org/forums/e-class-w...er-always.html
I use my cigarette lighter socket for radar detector and dashcam, so I want it to go off with ignition.
But have other socket in the rear and even tough about checking if it is under constant power, never went that far.
Did it on wagon where cargo area socket goes with ignition as well, but that again works for me as I taped into the wire with trailer lights converter.
Had the same problem with my E350. Could not get the trunk to open tried everything. After searching for a couple days I found you could get power to the trunk by hooking a charger to the relays under the passenger side floor board. Just had to pull the carpet back and remove a metal panel.
The big cable on the left is main starter cable, that goes via the floor and you can access it under the car (in case somebody has door locked as well). You can jump whole car via it.
