SeaFoam
SeaFoam
Has someone seafoamed their MB?
Und what about using this type of device
https://www.citizengoods.com/sales/9...starter_100716
Share your experiences, wanna know if it is safe for an MB vehicle.
2012 E350 sedan
Seafoam a good product but not needed
Don't know if you mean the gas treatment or engine treatment. If you follow MB oil change intervals with synthetic oil that meets MB specs, you should never need the engine additive. If you use top-tier gas you should never need the gas additive. Regarding gas additives, there are documentary videos online that show the cleaning performance of gas additives is minimal, at best.
Received 1,466 Likes
Stay away from seafoam. If you don't do it right, you can hydrolock your engine which means you need a new engine. It's just snake oil. It's only really used when you've got nothing to lose and it's no big loss if it doesn't work. I wouldn't use any snake oil on a car that's running fine. Even if it's not running fine, if it's one step from the junkyard then yeah maybe, but probably not an MB, they still have some value even when they're a junker.
I would stay away from using these kind of additives in any brand vehicle, unless the car is on it's last legs and ready fo be junked.
2010 e550 p2
this guy have done it , and i guess it worked out fine.
i was gonna do it , but smth tells me not to lol
would be nice if he could chime in with an update
https://mbworld.org/forums/e-class-w...afoam-diy.html
2010 e550 p2
Simple logic would tell you not to do it. What problem are you trying to fix? Where's the data that says this actually works? What's the risk/reward factor? That the car is still running fine afterwards isn't exactly a ringing endorsement, it sounds like the car was running fine before too. It's like playing russian roulette, everything is fine until there's a bullet in the chamber.
I use stabile 360 for storage only for my boats, generator, mower and golf cart. I also used it in my CLK550 during winter storage before I sold it. Never had an issue.
If you want to buy something for roadside emergencies or as a trickle charger for extended storage of your car, buy one approved for MB use. Be concerned about compatability with your vehicle rather than if it meets a specific price point. Otherwise you can do some serious damage to either your battery or potentially damage your car. Yes it is a good idea to have one of these. Just make sure it is the right one for your car and you know how to use it properly.
I already got the CTEK long term/Maintenance charger, but found about that other device that could be useful too. You know, without having to depend on other cars.
That is why I am asking, curious about MB cars.
Yeah, I saw a video where there is proof with before/after images of the cylinders of the car. It seems it cleaned up some carbon build up.
I can tell you this about seafoam and any other additive, When it first came out few years back I had 5 times the amount of carb rebuilds that year,90% said they had used seafoam fuel additive. Well Jetskis have plastic and rubber type parts in carbs, it actually softened the rubber so much so and even melted it in some.So if it does that in carbed engines I'm sure it has to affect the rubber parts in MB. fuel systems. I have always found if something is running bad or needs repair nothing in a can ,can make it right!!!! If its running well why would you add anything? I have built race motorcycles and race cars since my first when I was 12 a 1970 Yamaha AT1 125CC and numerous cars from a 1970 Firebird Formula to a 1970 nova SS Twin 4 bll. solid lifter, 4 bolt main, with a tunnel ram and cool can. Boats a triple engine Eliminator 1990 23' with 3 modded 2.5 offshores. None have ever needed anything from a can except motor oil. The only additive I have ever used with any success is STA-BIL and that should never be needed as you have no business running fuel older than 6 months if it has alchol in it. Hey just my 2 cents worth.
PaulE550 (08-08-2019)
