2004 E320 intermittantly wont crank. Please Help
The car was sitting for about 3 days. I went to start it and it cranked for about 1/4 of a second then nothing. I tried for about 15-18 times then it started like normal. This has been going on for about 2 months. Sometimes it starts right up and sometimes it takes 4-5 times before it turns over. It's been a little colder (from 75-85F down to 52-58F) lately. Any suggestions?
and starter itself. If it's not cranking at all then your starter is going to the shyttur.
and or your eis is starting to fail....
or switch. I refer to it as switch but everyone has their own references.... but yes, the thing you insert your key into....
Received 1,730 Likes
1922 Ford Model T / no OBD
I would start with checking the car voltage.
Takes about 5 seconds to display it on cluster and observe if it drops a lot when you turn all headlights on.
