Feedback on e550 m273 vs m278
1 Post
08 S550, 10 GLK350, 05 Clk500
Starting to consider a replacement for my CLK500. It has been and remains a great car at 150kmi. It has the m113 engine.
Should I view the m273 as more reliable in the long run than the m278? How about driving difference? I have never owned a turbo car.
The newer M278 biturbo has proven itself to be very well built with few problems. Adding that to the incredible power and torque of the turbo engine and there is no question it is the one to go for. The normally aspirated engine is nice but the new one is much better in every way from power, torque and mpg. Can't ask for more than that!
Only thing I can complain about has been the brakes. They suck. They stop the car fine, it's the vibrations that is killing this car for me. Already replaced pads and rotors at both ends and 7k miles later the vibrations are back and worse than ever.
Good luck finding one. When I was looking there were only a handful of them for sale at any given time in the entire Southern California area.
While the 278 is a wonderful choice, it seems OP has a budget and I think given the scarcity and cost of the 278, he should consider the 273. They are pretty inexpensive and arent too slouchy on MPG given the size of the engine. Certainly, the savings on purchase would go a long way at making the difference in fuel cost trivial depending on his level of use. Don't over look the pre-facelift models. Great vehicles and I for one have had no brake issues whatsoever. I may be wrong but it appears that the newer brakes are the ones with more issues , vibrations, etc. Happy hunting!
1 Post
Thanks for all your feedback. Not in a hurry. I will likely get the facelift model. Hope someone sorts out the brake issue. That sounds odd. Perhaps softer aftermarket brake pads will help. Did MB try something new and went for longer lasting compounds that eat the rotors?
I believe the brake problem was sorted out in the 2015+ E550s. I understand that a smaller (although still very large) rotor is used. I am approaching 20,000 miles on my 2015 and no problems at all
The M278 is a very nice engine, I missed it in my last E550.
The M278 sounds great, and with lot of low-end torque. I had the E550 for three years and drove it everyday, zero problem with the engine.
I do, however, have some creaking noises coming from the suspension during braking while turning. I had the bushings replaced, and it's still there. Not sure if it started when they fixed the brakes or it's due to my aftermarket springs. The thing is, the car never made sounds before the brake change.
The brake issues are with the 360mm rotor and even the new and improved rotor is warping! So much for improved! Go aftermarket and you will have better results. If you can handle 14 or less mpg in town and 27 on the highway go for the V8. I smile every time I drive my car. What else in life can make you smile every time? Children are close but the E550 is the top of the smile list!
Hi, I have owned both motors, 273 and 278. First in a 2007 CLK and second my
present 2013 E550 coupe. Both are great with lots of power. The 278 just has more
of a good thing. I don't think you could make a wrong choice.
My Post on The Brake Issue in August '15
I'll be curious to see how long these replacements last. Oh...they are the large rotors."
I'm on my third set at 15k miles! I think the reason they are being accommodating is so people don't make bigger waves about the problem. The less bad press he better. It is a huge safety issue as you might crash due to the bad brakes.
Dealer replaced my front pads and rotors under warranty. I've been breaking them in easily and so far so good. I have a few hundred miles on them.
