Upgrade Stock Xenon Bulbs
I have the OEM xenon lights stock on my car (pre-facelift). I've noticed that on the highway the headlights don't illuminate the road very well, can't see very far ahead and can't see the curb beside me. I was wondering if there's any better bulbs out there, or if there's anyway to tweak the headlights ie. raising the position of the light. Also i have noticed that when you turn the high beams on, the high beam light turns on and the low beams get brighter as well, is there anyway i could program that to stay on all the time? Thanks
The headlight aim can be adjusted. Look for screws on the top of the headlights marked L R or up down, can't remember exactly how they're labeled but my ILS-equipped 2014 has manual adjustment screws.
As for your other question.. your car has halogen high beams in addition to the bi-xenons. You can't just leave them on all the time because you'd blind other drivers and it's illegal.
SPONSOR/MBworld Guru
There are higher quality D1S bulbs available from reasonably priced Morimoto to top end Osram CBI. We can help with any. Let us know!
1 Post
2012 E350 4matic Coupe
Disappointed with the OEM bi-xenons even with the Osram 66144 CBI bulbs. I have a haze inside the headlight lens that I think might be affecting output.
Next month I'll be swapping the fresnel projector lens with the clear ZKW-R lens from theretrofitsource and cleaning out the haze from the inside. I'll try to do some before/after pics if I remember.
2014 C300 Sport
Edit: Hell you can see it on my sig on the right light lol.
I have also upgraded my stock xenon bulbs to philips xtreme vision 6000k and it's still very yellow.
I believe the problem is our lens in the projector. If you look at our lens, it is very cloudy and even has mesh dots to disperse the light. My 2015 Audi Q3 lens does not have this and with philips 5000k, it looks a lot whiter than my C250 with that crappy lens.
I'm looking for a local shop that can do the lens swap for me.
The haze is caused by the heat coming out from the projector. MB replaced twice my headlamps because of this. Now the third set also has it. I think the plastic is torched inside unless someone who has this problem and is not afraid of putting it in a oven to open it up and just see if you can wipe it off no aftermarket HID bulb would not cause it. I think it is just a bad design.
I'm not sure what you guys are on about. I have had many cars with HID (and one with LED) lighting from the factory. Including Acura TL, Nissan Rogue, Infiniti G37, Mazda3.. our current Optima has stock HID and we had a new Corolla with LED. The W204 has the best lights of the bunch, hands down.
Our Optima has stock low-beam projector HID with auto-leveling and LED fog lamps. The light it puts out is good, but the Benz is better.
I have a 2014 with the ILS. It continually adjusts the beam depending on traffic situation. It will stretch out the low-beam headlight reach on the highway as long as other cars are not close by.
Nope, I tried both 5500K osram CBI and now the philips xtremevision 6000k. Still yellow compared to now-my-wife's Audi. I hope it's not my ballasts going bad. Cutoff compared to Audi is ****, as well. Im going to try clear lens as I said and see if it improves. If it doesn't, then must be ballasts going bad.
2014 C300 Sport
Nope, I tried both 5500K osram CBI and now the philips xtremevision 6000k. Still yellow compared to now-my-wife's Audi. I hope is's not my ballasts going bad. Cutoff compared to Audi is ****, as well. Im going to try clear lens as I said and see if it improves. If it doesn't, then must be ballasts going bad.
Same here for my C200 Kompressor pre-facelift.
2 issues:
1)xenon lens have this haze like humidity.
2)headight cover has small spots like tiny stones hit it.
Recently changed completely the passenger's side headlight(a lady broke it..)
and the lens is crystal clear but the colour of the xenon lamp is more "yellowish" than the driver's side which is "fogy" white.
Here are some pics.
Driver's headlight
Passenger's headlight (new)
Driver's xenon lamp
Co-driver's xenon lamp (new)
Co-driver's xenon lamp (old)
2 issues:
Here are some pics.
Driver's headlight
Driver's xenon lamp
2 issues:
Here are some pics.
2 issues:
Here are some pics.
You either replace both of them for the same so they adjust at the same time or you deal with it for a month or two until it gets whiter.
Any Pics? The lens can't be polished?
Q. Did you end up doing the the swap with morimoto clear lens?
If so can you post pics?
