C63 Brake pads
2015 C63 AMG Coupe
C63 Brake pads
I just services my car twice for the B service and the dealer told me my rear pads are worn. Any suggestions for better than OEM pads or should I stick to the OEM. Obviously the dealer asks for around 700$ without taxes just for the back pads which seems like a lot. Is it really worth doing it at Benz and if not which pads are the best for a 2015 C63 Coupe.
Thank you
Thank you
2015 C63 AMG Coupe
Received 2,810 Likes
I prefer something a little more fashionable like this
I have EBC Blue Stuff brake pads on my car currently. I think they are better than stock. If you are changing them out yourself make sure you buy new pad sensors. They are not worth trying to save. The clips break really easy.
Porterfields are a good option for the street.
http://www.formymercedes.com/porterfield.asp
Just don't try to put them down your pants.
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
Better than OEM pads / best pads... better (or best) for WHAT? Best grip levels? Best modulation? Longest lasting? Low dust? Lowest rotor wear? Street use or track use? Do you want them to grip at -25C? Most of these are mutually exclusive... and if you don't already know this, I would respectfully suggest you stick with the OEM pads. They are not the best in any one particular area, but are very good at all of them - something that you'll be hard pressed to find in an aftermarket pad. Various aftermarket pads may be better than the OEM pads in one or two specific aspects, but that always comes at the expense of something else.
C63 AMG, P30
Except for Endless MX-72
Im with Mort. I quite like the Porterfield R4S, and really like dealing with Jerry at the site he posted.
Having said that, I also dont think the OEM are all that bad.
porterfield r4s are a popular choice
Also rear pads are $225 so that $700 quote is a rip if they are just replacing the pads. Even if they do 2 hours of labor it should still be below $500.
And if they do two hours of labor they were on a smoke break for half that time.
My point was that even if they "overcharged" for two hours of labor there's no way it should be $700 just to do pads. That's nuts.
