Red Light Flashing on Key
'13 E550 Sedan, '15 S550 Coupe, '15 RR Autobiography
Hi all,
Recently my key started flashing a red light night the panic button every time I press any buttons (lock, unlock, open trunk). I read that this could mean my key battery was low but I'm not getting a warning when I start my car. Any ideas as to what this could mean?
2013 E550 4Matic
I'm responding to this thread because when I initially saw your username I thought it said "colon biter" which is my new favorite insult
As for your issue, it probably is a low battery. I had a dead battery in one of my fobs and it didn't unlock the car or start it (I have Keyless-GO). I think it's a CR2025 battery, but I might be wrong (maybe CR2032). It's easy enough to pop off the back of the fob and check for yourself. If you don't have Keyless-GO, you probably won't notice this because you have to put it into the ignition slot and it should still work that way (my Infiniti fob worked if you put it in the slot, and it also had the keyless feature, so that's how I figured out that fob had died too).
Received 4,417 Likes
'71 Pinto
If you have keyless go it may be responding to wakeup request. Attachments cover battery.
need2speed (12-05-2016)
So the light has always been blinking and I just haven't noticed it? The first pictures says the battery is working properly if the check lamp lights up..
2014 Mercedes Benz E250 Bluetec
Well, I didn't see the red light flashing and the message on my dash about my key fob battery but my car couldn't find the key so I replaced it and it did the trick. Mine's equipped with Keyless GO.
How are you guys getting the Low Key Battery Warning messages, it never showed up on mine? Just says that it couldn't find/recognize the key at the time.
Received 1,467 Likes
My car says "Replace Key Battery", which I understand it is telling me battery is getting weak. Everything still works fine at this point though.
