CAR WILL NOT START AFTER CHANGING SPARK PLUGS
What will cause my E63 not to start after changing spark plugs. I had an oil leak on the passenger valve cover. i decided after i got into the job to replace the spark plugs. i completed the job and now the car will not start. Any help would be appreciated. Will the wrong plugs cause the car not start? I purchased the Denso as that was all available in the are today. Denso FXE22HR11 3442
Bahnstormer (12-07-2016)
I think I found the problem. I found a wire jammed between the head and the valve cover. I removed wire and check fuse box and found one fuse blown. I will get a fuse in the morning and try her out again. I am looking for a fuse box legend so I will know what fuse is blown.
2013 ML350 Bluetec
You should find a fuse chart on the passenger compartment fuse box door. It's on the driver's side panel that the door closes against. Check your owner's manual for the exact location. If you don't have an owner's manual, find yours here:
https://www.mbusa.com/mercedes/servi...owners_manuals
Pinched wire between the head and valve cover caused intermittent shorting of the alarm system.
Imagine having an intermittent kill switch (always when you don't want it).
