ML-320 Crank No Start
Old 12-05-2016, 09:22 AM
rancherprice's Avatar
97 S320, 02 ML320, 02 ML500
Went out after school to go home and my 2002 ML-320 cracked over but would not start. I have checked out the spark, fuel pressure, injectors, timing and compression. All good. Replaced the crankshaft position sensor, pulled the valve covers and checked the timing chain, all good. Any ideas?
Old 12-05-2016, 12:02 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
If the CEL is not illuminated, then it is a fuel issue, probably the pump.
Old 12-05-2016, 04:05 PM
i checked the fuel pressure at the connection on the engine and it was ~30 psi.
Old 12-05-2016, 11:37 PM
And what is the pressure while cranking the engine?
File Type: pdf
Old 12-06-2016, 09:31 PM
The engine won't crank because I think I have too much disconnected. But when I turn the key on the pressure comes up to 48 psi. After 30 min with the key off it came down to 32 psi. The starting pressure is high enough that it should atleat try to start isn't it?
Old 12-07-2016, 01:14 AM
Are you getting a message in the odometer window saying, START ERROR?
Old 12-07-2016, 08:52 AM
No START ERROR.
Old 12-08-2016, 02:20 AM
I don't know what you have removed, as you said earlier, but with a fully charged battery, crank the eng. and at the same time look at the Tachometer and see if the needle bounces to approx. 200 RPMs.
If it doesn't then it is a faulty Crank. Position Sensor.
Old 12-09-2016, 08:52 AM
CPS is OK. Tach comes up to 200 while cranking.
Old 12-09-2016, 09:45 AM
Turn the key to pos. #2 and check for 12v on both contacts at fuse #19.
Old 12-09-2016, 10:30 AM
Is the Check Eng. Light on?
Turn the key to pos. #2, and do all the Telltale Lights illuminate, especially the CEL?
Then wait about 5 secs., is the CEL on?
Attached Thumbnails ML-320 Crank No Start-instrument-cluster-2002-2005-1.jpg
Old 12-10-2016, 05:13 PM
All of the tell tale lights come on including the CEL. Only the air bag and SRS lights go of after 5 sec.
Old 12-10-2016, 05:22 PM
When I pull the fuse, I get 3.8 V on the front leg and 12.4 V on the rear leg.
Old 12-10-2016, 05:38 PM
The fuse is blown. Replace it, but understand that fuses blow because of an existing problem.
Old 12-10-2016, 11:08 PM
the fuse is ok. Those readings were with the fuse pulled out. With the fuse in I get 12 V on both sides.
Old 12-11-2016, 04:00 AM
Does the eng. still turn over?
Is everything back in place?
If so, turn the key to pos. #2 and while doing so watch the RED LED light. Does it quickly blink once?
Old 12-11-2016, 05:27 PM
YES, it blinks one time.
Old 12-12-2016, 04:56 AM
I should of thought of this earlier. Turn the key to pos. #2 & check fuse #26 for 12v.
Old 12-12-2016, 08:12 PM
Fuse is good. 12V both sides.
Old 12-12-2016, 11:59 PM
Does the eng. still turn over? Hopefully you didn't run the battery down.
Old 12-13-2016, 08:16 AM
Engine does still turn over. Do you have instructions for how to check the timing chain? I have the valve covers off and need to know what marks I am checking on the crank and cams.
Old 12-13-2016, 08:26 AM
You are barking up the wrong tree with the timing chain. Are you absolutely positive you are getting enough fuel pressure?
Old 12-17-2016, 04:09 PM
I just put the fuel pressure tester on again and it came right up to 50 psi when I turned the key on. Bounced around right there while I cranked it.
Old 12-18-2016, 12:07 AM
Remove both top covers to the fuse relay box, turn the key to pos. #2 and probe the cir. #15 stud for 12v.
Also do the same to the cir. 15 stud at the right side fuse panel.
Attached Thumbnails ML-320 Crank No Start-fuse-box-cir.-15-stud.jpg   ML-320 Crank No Start-fuse-box-cir.-15-stud-r-s-kick-panel.jpg
Quick Reply: ML-320 Crank No Start
