2005 ml500 P0104
Old 12-08-2016, 11:21 AM
TWSOCKS's Avatar
2005. Ml500. 1988 190e
2005 ml500 P0104
it started spitting and hesitating at stop lights when trying to step on the gas, sometimes stalling other times spitting and going on, after each cycle throwing CEL and code p0104, tried new MAF, not as bad but still the same, checked all hoses and filter and box. Meter says MAF is fine but throttle body readings are peculiar.......HELP can't get rid of p0104 just keeps coming back to haunt me with hesitations etc.
Old 12-09-2016, 02:22 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Do you have a DVOM (Digital Volt/Ohm Meter)?
Old 12-09-2016, 06:18 AM
TWSOCKS's Avatar
Yes
Old 12-09-2016, 06:23 AM
TWSOCKS's Avatar
Have measured each one all check ok but Mercedes told the mechanic that they were ok on top end but not ok on bottom end
Old 12-09-2016, 10:07 AM
You have measured each one, what?
Old 12-09-2016, 02:02 PM
TWSOCKS's Avatar
2005 ml500 P0104
Yes 2 prior mafs were both check with volt meter
Old 12-09-2016, 02:51 PM
Did you do these tests?
Attached Thumbnails 2005 ml500 P0104-ecm-connectors-late.jpg   2005 ml500 P0104-ecm-location.jpg
File Type: pdf
Old 12-09-2016, 03:59 PM
TWSOCKS's Avatar
Ml500 tests
no im sure he has not I'll forward them Thanks
TWSOCKS's Avatar
Ml500 tests
Old 12-09-2016, 11:39 PM
TWSOCKS's Avatar
Ml500
maj Dundee. You don't happen to be in Maryland ?
Old 12-10-2016, 02:41 AM
Bronx, NY
Old 12-10-2016, 10:27 AM
TWSOCKS's Avatar
Ml500
wish you were here , I'm going back to the garage today and see if he can run those tests !
Old 12-10-2016, 01:42 PM
Please UPDATE YOUR PROFILE in USER CP to include the ML.
Old 12-10-2016, 07:33 PM
TWSOCKS's Avatar
Ml500 p0104
Now it won't throw codes at all. But it's all when you stop at a light or stop sign and pedal it ,, wants to still spit etc but now no codes But while I was under hood trying to give it gas I kept hearing a vacuum leak at very back of motor and after you get it to take gas it's fine just the low end gas pedal not 100% sure where hissing is but middle of back of motor But all other tests ok
Old 12-11-2016, 05:31 AM
Here is a photo of the vacuum lines at the rear of the eng. To get a good look at things you will have to remove the large plastic cover on top of the eng. Just pull it upwards and store in the trunk.
Using a large mirror look at all the hoses connected, especially the T-conn. at the top of the photo and see if it has a crack in it.
Post back with results.
Old 12-11-2016, 11:05 AM
TWSOCKS's Avatar
ml500 p0104. Now this morning I left battery unhooked for 1 hour. And drove it 5 minutes no Cel but p0104 is back after completely clearing codes
Old 12-11-2016, 12:15 PM
Because you disconnected the battery does not eliminate the vacuum leak. A vacuum leak that will occur whenever it wants to.
Old 12-13-2016, 09:30 PM
TWSOCKS's Avatar
Ml500
Thanks for all your help Maj Dundee. We took off manifold fixed bottom vacuum line and cleaned everything and replaced every hose etc..... and sooo far it's Grrrrrreeeeaaatttt .
Old 12-14-2016, 04:24 AM
Which hose was it? Was it one of the hoses in the photo I supplied?
Please indicate which one it was so future members will know.
Old 12-14-2016, 11:00 AM
TWSOCKS's Avatar
Ml500
i "Believe" the one in front of manilfold that actually goes inside of the manifold front bottom we used a metal barb and put liquid steel around it .. to seal it and resealed the manifold back together and new gaskets etc... but we also replaced every hose and gasket their was .
Old 12-14-2016, 03:42 PM
I hope you learned from this experience. Because a code is thrown, P0104, does not necessarily mean that the part is faulty and must must be changed, MAF Sensor.
Old 12-14-2016, 06:19 PM
TWSOCKS's Avatar
Ml500
yes how true.... although we did change out 2 mag sensors in the 1st few days not 100% what was the problem since we fixed 4-5
Quick Reply: 2005 ml500 P0104
