CLK55 AMG Kompressor
Old 12-17-2016, 06:21 PM
ChiCho55AMG's Avatar
W209 CLK55 AMG Kompressor, ATV BRP 800 CAN-AM
It's been a while that i have done it , but was little busy and away from here. Engine is coming from G55 Kompressor , huge and BIG power difference between before and now, car is running perfect , engine has very very low mileage .
ProjectC55 (12-30-2016)
Old 12-17-2016, 09:01 PM
AndreNickiAMG's Avatar
W209 CLK55 AMG
damn very nice, what are new specs?
Old 12-17-2016, 10:53 PM
tw2
tw2's Avatar
2005 E55 AMG, 1991 MR2
Fantastic! There must be several people running this now. I definitely plan to do the swap when the time is right.
Did you use the stock CLK headers?
Old 12-18-2016, 04:54 AM
Car is stock but something on the way
Old 12-18-2016, 04:58 AM
Yea i think so,it's little bit expensive but worth each bucks when you put your hands on the right engine.... Yes sure,stock CLK Headers MUST be used, even later when i want to put mid or long tube headers, i will have the get the ones of W209.
Old 12-18-2016, 01:58 PM
tw2
tw2's Avatar
Thank you, I asked as I am considering having long tubes made sometime and just wanted to make sure they would work with the supercharged engine which I thought they must considering it is the same basic block.
Old 01-20-2017, 02:39 PM
Anytime ! Don't waste your time on headers now , if you can start from now to start the swap then don't delay more . Keep the headers for later, now let the show start with you by loading the new engine then more suspense with headers , pulleys , etc
Old 01-21-2017, 10:16 AM
kb24forlife24's Avatar
None for now
That's awesome, how easy/difficult was the swap?
Old 01-21-2017, 11:17 AM
Nothing is difficult, just buy an 55k engine and tranny with harness, ecu ,tcu and cooling...
Then installing the ecu in the sam is easy, same bosch me 2.8.
Old 01-21-2017, 11:45 AM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
Looks like a lot of fun Chico,
Hopefully the G55 is similar oil pan wise to the CLK/E otherwise retrofitting will turn into headaches.
The K has special oil pump n baffles which might not work if the pans are different.
Keep us posted on the retrofit details. It takes a lot of guess work out of crafting Benz.
Agree using OEM manifolds until one is ready to tune for headers.
Cheers, Gator
Old 01-21-2017, 12:44 PM
Cheers, Gator
Anything other than OEM or changing from factory is lot of fun, the show almost starts.... Everything looks oem , everything was replaced came back as OEM. The work as general was normal , only small work for VIN swap , modifying SCN for CLK and making the ESP works on it without SBC.
All working well , not a single wire is missing, as engine tranny all was plug and play, only little work for coding as said first .
Old 01-21-2017, 01:17 PM
None for now
Just have to figure out how to register it in CA
Old 01-21-2017, 08:24 PM
blackbenzz's Avatar
haters crazy
Who did your coding? No errors? Good luck getting headers to fit in a W208 chassis. Unless you have a w209
Old 01-22-2017, 02:29 AM
sick430's Avatar
CLK Cabrio
Its a w209, from his description 04
Old 01-22-2017, 05:16 AM
A local friend here did it just as it is OEM from origin ! No errors, all working great ! Its w209 as @sick430 said , there is a picture under my signature for my engine which is showing that its w209 chassis, the picture is not showing?
Old 01-22-2017, 09:54 AM
blackbenzz's Avatar
haters crazy
Oh cool. I can't see signatures on my phone. I've had a M113k motor for a while now with Weistec blower and other mods in my W208. It's an animal
Old 01-22-2017, 02:14 PM
None for now
I really wanna do this to my 500
Old 01-22-2017, 08:44 PM
2MCHCAR's Avatar
Supercharged CLK500 & ML500
+1
Like many Mercedes projects, one can get all HW to fit but the most difficult part is getting the SW to work. If someone in the United States wanted to perform this swap, what tuner/shop can perform all the SW changes (including VIN change, no ESP errors, tuning, SCN coding, etc.)?
kb24forlife24 (01-22-2017)
Old 03-25-2017, 07:24 PM
FutureAMGxx's Avatar
C55 AMG
Originally Posted by 2MCHCAR
+1
Also curious^^
Eurocharged????
Old 06-20-2017, 10:34 PM
KIWI KEN's Avatar
CLK63, CLK 55 kleemann, Nissan GTR N1
I did this same CLK55 compressor conversion about six years ago but I still have the ESP compatibility error which means that dyno mode will not switch on manually but when the dyno tuning equipment is connected to the engine it is automatically on.
The car was dyno tuned producing 360 RWKW which is impossible to use fully on the street because of the traction control interference.
Does any one know how to fix the ESP-SBC engine ecu compatibility issue?
Old 06-22-2017, 12:09 AM
globalauto's Avatar
s320
I bought an 03 209 55 , it sat up for a long time and a rat go under the hood ate up harness even got in the inside at the radio fiber wires .. But I can't find where the small vacume hose that comes off of the brake booster connector goes ? Can amine help me ? I think it went into a harness between the cowl under the wipers ? But I don't see where it goes in the car or where it connects to ?
Old 06-22-2017, 12:11 AM
globalauto's Avatar
s320
Had the pet ferret chase the rat out ...��������
aerG500 (05-12-2020)
Old 06-22-2017, 12:14 AM
globalauto's Avatar
s320
Where des this small vacume line connect too ? Thanks
Old 06-26-2017, 03:51 AM
globalauto's Avatar
s320
Bump
Old 06-28-2017, 07:58 PM
globalauto's Avatar
s320
Anyone can answer this I can't find this on the parts diagram? Thanks
Quick Reply: CLK55 AMG Kompressor
