GL Class (X164) 2007-2012: GL320CDI, GL420CDI, GL450, GL550
Gl550 Tire Ring Problem
Old 01-15-2017, 02:52 PM
Antony15828's Avatar
2011 Mercedes GL 550
Gl550 Tire Rim Problem
I have a serious problem. My mom just recently got an used 2011 gl550 and the tire rims (the AMG ones) are breaking basically every week, resulting in the tires leaking air. We have Pirelli r21 wheels, and we are desperate. What is the correct tire pressure for these wheels? We cannot afford having to repair these rims every week!
Old 01-15-2017, 04:57 PM
BlownV8's Avatar
Received 1,001 Likes on 808 Posts
E55, GLS450, GL63, GLE350
What do you mean by tire rings?
Old 01-15-2017, 06:35 PM
Tire Rims. Sorry
Old 01-15-2017, 06:55 PM
DennisG01's Avatar
'08 GL 320 CDI
The rims are breaking? One would think that after 4 weeks (and four new rims), the problem would be solved?
What exactly do you mean by "breaking" Do you mean the "bead" is breaking? Meaning the tire is coming unseated from the rim? Hitting a lot of potholes? Corrosion on the rim? Since you (you're mom) just recently bought it, I would first take it up with the place you bought it from.
Follow the tire pressure label on the inside of the driver's door jamb.
FYI, you have Pirelli r21 TIRES, not wheels. Wheels are the metal things.
Old 01-15-2017, 07:29 PM
BlownV8's Avatar
Are they chromed? Are the rims cracking from potholes? 45 PSI should help protect the rims.
Old 01-15-2017, 07:40 PM
Dude.. so sorry haha.. english is not my first language and I was in a hurre then. We are getting what appears to be little cracks on the inside part of the wheels. These appear at least once a month. We had already fixed them at least four times.
I live in a country were the roads are not in the best condition, but they are not that terrible. These wheels are supposed to be strong.. We never had these problems with our previous cars.
Old 01-15-2017, 07:42 PM
Isn't 45 psi a little too much..? I don't know dude..
Old 01-15-2017, 09:04 PM
BlownV8's Avatar
I run at least that in my 22's and have never had issues with bent or cracked rims. If you have bad roads, you need the extra pressure to keep the impact from the potholes away from your rims.
Old 01-16-2017, 12:06 AM
You got a gl too? Sigh... Still a little uncertain but I'll try anything that could work
Old 01-16-2017, 09:34 AM
DennisG01's Avatar
'08 GL 320 CDI
No worries
Can you post a picture of what's happening? Yes, definitely check the pressure to make sure you have enough in there. As the wheel/rim size (diameter) increases, the aspect ratio of the tire (the size of the sidewall) goes down and you end up with less "margin for error" of your tire pressure. On top of that, the outside edge of the rim is effectively closer to the ground and more likely to strike the inside edge of a pothole, too.
Old 01-16-2017, 12:12 PM
alx
alx's Avatar
you got stress fractures. those wheels were beaten to death in their previous lifetime and now (probably in a new climate) the fatigued metal is expanding/ contracting and is cracking.
my feeling is that you will end up ditching those wheels altogether. btw, i wouldn't be surprised if those are some cheap replicas.
also make sure your tires are xl- rated and inflated to 40-42 psi when cold.
Old 01-16-2017, 11:32 PM
EWT
EWT's Avatar
11 ML550, 95 Supra TT, 07 Audi A4
I've cracked two on my 550 and never bent/cracked a wheel in my life prior to the GL. They're not very strong. They crack where the spoke joins the rim which causes a slow leak. The price on a used wheel doubled from wheel #1 to #2, and there weren't many available the last time it happened (couple of years ago).
Quick Reply: Gl550 Tire Ring Problem
